jerry garrido (Uemjg)
Registered Member Username: Uemjg
Post Number: 18 Registered: 10-2010 Posted From: 70.244.35.191
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 8:40 pm: | |
I recently changed the motor oil in my bus's engine, an 8v71 (1975 model bus). I used straight 40w Delo...my question is will the oil pressure reading at idle and cruising speed be different using a multigrade oil vs straight 40wt? |
Bill Gerrie (Bill_gerrie)
Post Number: 446 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 9:00 pm: | |
Jerry DO NOT even think of useing a multi grade oil in a 2 stroke engine. This has been discussed here many times. Bill |
Post Number: 19 Registered: 10-2010 Posted From: 70.244.35.191
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 9:18 pm: | |
you mean don't use a 15w40 delo oil? |
Post Number: 1259 Registered: 3-2007 Posted From: 69.69.20.25
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 10:03 pm: | |
DON"T USE ANY MULTI-GRADE IN A 2-STROKE!! they will throw more oil than you can keep in LOL Always use straight 40 Delo in 2-cycle as Bill has stated. Good Luck. gomer |
Post Number: 1260 Registered: 3-2007 Posted From: 69.69.20.25
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 10:11 pm: | |
Oops Forgot! Oil pressure will drop when using multi grade oil in a DD. The sae ratings of multi grade oil is it will be a 10 wgt until it warms up and will change viscosity as it get warmer to 40 wgt [10w40] DD are like any vehicle in cold temps oil is thicker as you use straight 40,That is why they made lighter sae ratings. Hope this clarifies the thang LOL If not go to AMSOIL.COM and search the viscosity ratings of oil. VERY INFORMATIVE!! If you can't find it,give me your address and I,as a dealer will mail anyone who ask for it. No charge except to flippers and dog lovers LOL Gomer |
Post Number: 20 Registered: 10-2010 Posted From: 70.244.35.191
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 11:06 pm: | |
I agree about the type of oil to use, but I am also looking for ideal oil pressures at idle and at cruising speed. |
George M. Todd (George_todd)
Post Number: 1189 Registered: 8-2006 Posted From: 99.29.78.69
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 02, 2011 - 11:42 pm: | |
Jerry, Most of our Detroits will only make about 10 psi at idle warm, and about 40 psi at cruising speed. Please add me to the list of people telling you NOT to use multi-weight G |
Post Number: 1457 Registered: 10-2006 Posted From: 66.82.9.15
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 03, 2011 - 7:18 am: | |
"Most of our Detroits will only make about 10 psi at idle warm, and about 40 psi at cruising speed." If the idle is 10 psi the factory air cond on many coaches would not come on.. In order to engage the clutch to the AC the oil pressure had to be below 5psi on most GM. So low pressure at Idle is no big deal, esp if the idle speed is by Da Book.. FF |
Mel La Plante (Mel_4104)
Post Number: 151 Registered: 7-2006 Posted From: 173.180.126.136
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 03, 2011 - 10:29 am: | |
ll agree on this, get that multi grade out of your motor before it starts to give you greif as once that starts it is to late to stop it from causing major trouble. there is a good side to this when you drain this oil out the inside of your motor will be a lot cleaner. it is like when the used car dealers dump a qt. of tranny fluid in a car motor so they can show you a nice clean dip stick when it is just a old poorly looked after car |
Post Number: 21 Registered: 10-2010 Posted From: 70.244.35.191
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 03, 2011 - 10:39 am: | |
Thanks guys...my first oil change and I did use straight 40. |
Post Number: 568 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 2 (Vote!) | Posted on Thursday, March 03, 2011 - 12:34 pm: | |
"Straight 40" ...something that's hard to find in San Francisco..... just sayin...! |
Post Number: 410 Registered: 7-2004 Posted From: 67.141.71.22
Rating:  Votes: 1 (Vote!) | Posted on Thursday, March 03, 2011 - 12:48 pm: | |
you spent a lot of time there Jack? |
Post Number: 2038 Registered: 10-2003 Posted From: 71.58.71.157
Rating:  Votes: 2 (Vote!) | Posted on Thursday, March 03, 2011 - 4:44 pm: | |
I think many owners observe this low pressure at idle, but don't talk about it since the engine works well otherwise. The ones with the high idle numbers need to get an accurate gauge. |
Post Number: 570 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Thursday, March 03, 2011 - 9:58 pm: | |
The Idle number causes me light-headedness... so I'm going for an appropriate gauge 0-35/40 I imagine a decent ZFuel pressure Gauge would even be better than the 80 lb.'er now in the dash. Dal... We're just a Suburb.... (Message edited by Jack_fids on March 03, 2011) |
Dave Walker (Chrome_dome)
Post Number: 232 Registered: 3-2010 Posted From: 75.210.144.169
Rating:  Votes: 1 (Vote!) | Posted on Thursday, March 03, 2011 - 10:22 pm: | |
Jack nothing worse than light headedness in SF,LOL Dave |
Post Number: 571 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Thursday, March 03, 2011 - 10:51 pm: | |
...OR better..! |
George Martinez (Foohorse)
Post Number: 396 Registered: 1-2010 Posted From: 72.211.128.245
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 07, 2011 - 2:01 am: | |
Hippies |
Post Number: 608 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 07, 2011 - 11:25 am: | |
Jack, you want a gauge with a range of about twice the high running pressure. If it runs at 40, use an 80 or 90lb gauge. You want the reading to be about mid gauge when at normal temps & RPMs. |
Post Number: 448 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 07, 2011 - 12:13 pm: | |
So, are you saying that using multi-viscosity oil is gay? |
Post Number: 582 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Monday, March 07, 2011 - 2:00 pm: | |
If I was... I would have! Word play is all in the mind of the reader. Perhaps Multi-Vis is happy but I know nothing about gay preferences. I do know that of all the Air Cooled engines I have torn down the worst ones were full of sludge & the owners used MV Oil. (Message edited by Jack_fids on March 07, 2011) |
Post Number: 397 Registered: 1-2010 Posted From: 72.211.128.245
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 07, 2011 - 2:31 pm: | |
Les I bet that seal that Nellie met in an Alaskan bar would have something to say |
les marston (Les_marston)
Post Number: 295 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 07, 2011 - 6:06 pm: | |
George. you completely lost me? What seal? and where is Nellie anyway? |
Post Number: 398 Registered: 1-2010 Posted From: 72.211.128.245
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 08, 2011 - 12:09 am: | |
Les read .... it was a beautiful day until I hit the start switch part II... Nellie laid it all out nice and clear. And Les buddy ....PLEASE keep up with the program I can't hold your hand too, I'm busy cutting up and disposing corvairs here |
Post Number: 585 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Tuesday, March 08, 2011 - 1:51 pm: | |
Translation: ...I gave him a scissors and a bunch of old Corvair magazines... |
Post Number: 423 Registered: 7-2004 Posted From: 98.20.61.199
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 08, 2011 - 2:04 pm: | |
He's making paper dolls?
Post Number: 586 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Tuesday, March 08, 2011 - 8:00 pm: | |
He THINKS he is... and I'm running out of Band-Aids..! |
Post Number: 296 Registered: 1-2010 Posted From: 68.151.225.213
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 08, 2011 - 8:08 pm: | |
oh my! I feel so out of the loop not to get the cross thread reference. I sure hope those scissors are the safe kind and not the pointy ones. Remember George, always run with scissors if they are pointy. Weren't the Corver magazines the best part of that whole car line? At least the paper was shiny and didn't rust as fast as the cars did and rolled up made a quite good fly swatter. I wonder if they could also be employed in an attempt to paper train a penguin. Might be some value in Corver after all |
Post Number: 424 Registered: 7-2004 Posted From: 98.20.61.199
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 08, 2011 - 8:13 pm: | |
Rolled up it's quite possible they could be used in Penguin training.... for all the good it would do. Kind of like beating on a dead horse to make it run faster.... |
Post Number: 588 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Wednesday, March 09, 2011 - 3:14 am: | |
.. Nothing like repetitive experience eh? Dal? and to make a Penguin train all you have to do is hang a shrimp necklace on them backward... (Les & Chromie...push the button below for the joke)
Brian Evans (Bevans6)
Post Number: 19 Registered: 5-2009 Posted From: 65.92.54.2
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 09, 2011 - 8:38 am: | |
You know what, it's kind of refreshing to read a thread that has evolved to the point that it has absolutely nothing to do with the point of the thread... Kind of chaos rules, dude... Brian |
Post Number: 425 Registered: 7-2004 Posted From: 98.20.61.199
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, March 09, 2011 - 8:39 am: | |
Brian, weren't we talking about how to render the oil from a Penguin? |
Post Number: 589 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 1 (Vote!) | Posted on Wednesday, March 09, 2011 - 12:08 pm: | |
Seems to me .... that once the topic of conversation has run out of steam, informal banter usually follows, face to face & in the Cyber world. How are the wife & kids Brian...? Got that Coach ALL finished yet? ...when did you stop beating your dog? gee, that water soaked plywood countertop sure looks great! Oh and fwiw & BTW... Chaos rules the universe... We as humans try to structure events in vain attempts to make them predictable thus giving ourselves a sense of security and order.... mastery of our "fantasy universe"! (we even invented & believe that "guarantees" & "Laws" provide "certainty" in our futures...Pension funds & Wall Street anyone?) (In case you find reasoning, logic & chaos interesting you might want to read THIS: http://www.nytimes.com/2011/03/09/science/09guitar.html?hpw ...about how "REASONED & LOGICAL we as Humans really are!) Chaos is THE LAW, we just have fooled ourselves for the last 150 years into the belief that Technology & more rules will eliminate that one thing we have grown to fear most... the random unpredictability & uncertainty of Chaos. In REALITY, it's the one thing we can ALWAYS count on! I say roll with it, make chaos work for you! Hey Dal, can you forward a daily schedule & menu for the Shindig.... I want to be CERTAIN of EVERYTHING before I chain Fooey to the rear bumper & head ...BACK EAST where they say things like... Tawl Pawl sar a Dwag on Longgg Island warshing it's e-ahs in the Wah-tah..! . . ( (Message edited by Jack_fids on March 09, 2011) |
Post Number: 2045 Registered: 10-2003 Posted From: 71.58.71.157
Rating:  Votes: 5 (Vote!) | Posted on Wednesday, March 09, 2011 - 5:11 pm: | |
might be why we have fewer posters anymore and the other site has been growing past few months |
Post Number: 426 Registered: 7-2004 Posted From: 98.20.61.199
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 10, 2011 - 2:26 pm: | |
Chessie, the other site has been growing by leaps and bounds for a couple of years. I doubt that a bit of humor, or a lightening of the load of the worries that go along with bus ownership has much to do with it. If a hobby doesn't come along with a sense of humor, then it can't be a hobby, it would fall into the category of a job, I would hate to live or be associated with anyone that has no sense of humor. "A person without a sense of humor is like a wagon without springs — jolted by every pebble in the road." Henry Ward Beecher "A keen sense of humor helps us to overlook the unbecoming, understand the unconventional, tolerated the unpleasant, overcome the unexpected, and outlast the unbearable." Billy Graham "Keep your sense of humor. As General Joe Stillwell said, 'The higher a monkey climbs, the more you see of his behind'." Donald Rumsfeld |
Kat Battersby (Ramblinruby)
Registered Member Username: Ramblinruby
Post Number: 17 Registered: 5-2009 Posted From: 66.18.163.175
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 18, 2011 - 9:08 pm: | |
I have a 64-4106 and am looking for info on air leveling systems. Anybody have any info on that? Thanks, Kat |
Post Number: 1283 Registered: 3-2007 Posted From: 71.55.183.81
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 18, 2011 - 9:30 pm: | |
Kat; I along with others will try to help you on this. You needed to start a new thread on this so it would bring more attention. NOW What is the problem? We understand the system now we need to know what it is.. LOL Gomer |
Post Number: 18 Registered: 5-2009 Posted From: 66.18.163.175
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 18, 2011 - 9:58 pm: | |
Hi Gomer, I will start a new thread...lol. Sorry... Kat |
Post Number: 645 Registered: 1-2009 Posted From: 72.211.128.245
Rating:  Votes: 3 (Vote!) | Posted on Monday, March 21, 2011 - 1:46 pm: | |
Kat .. you have no idea how lucky you are that the Thread Police dint apprehend you for your "flagrant violation" of their unstated "rulez" once they have BRANDED you the enemy you have to carry that on your permanent record FOREVER..! |
Post Number: 1285 Registered: 11-2005 Posted From: 173.202.25.140
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 21, 2011 - 7:50 pm: | |
Jack, You must be off your Meds again!! |
Post Number: 1200 Registered: 8-2006 Posted From: 99.172.182.105
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 21, 2011 - 10:40 pm: | |
Its a psychiatric condition that requires meds! |
