Floyd Lillies (Flois)
Registered Member Username: Flois
Post Number: 10 Registered: 1-2006 Posted From: 64.114.143.93
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 04, 2011 - 12:01 am: | |
My audible low air pressure warning buzzer on my 1984 MC9 stopped working and I want to replace it but can't find it ... where do I look for it? (can't follow the sound because there is none!). Thanks! |
Iver (Mciv)
Registered Member Username: Mciv
Post Number: 44 Registered: 11-2006 Posted From: 70.69.131.252
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 04, 2011 - 3:07 am: | |
The buzzers are normally located in the front junction box below the driver accessed from the outside. Usually above the terminal board and to the right of the circuit breakers. You might have more than one buzzer in that area. Iver. |
Post Number: 1386 Registered: 12-2000 Posted From: 75.204.165.247
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 04, 2011 - 8:49 am: | |
Our low air buzzer is in the lacation listed above and is about 1.5" square and about 3/8" thick. A couple times, our buzzer quit working and a light top on it with a screwdriver hanlde corrected the problem. Jack |
John Lacey (Junkman42)
Post Number: 130 Registered: 3-2007 Posted From: 209.105.170.20
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, March 04, 2011 - 10:17 am: | |
Floyd, I have replaced My buzzers with solid state sonalerts! You can find them on ebay really cheap and if You desire, different sound patterns can be had. I now know which system has a problem by the different tone patterns! I bought Mine with mounting brackets used for a couple of bucks each! John L |
Cory hart (Chart1)
Post Number: 65 Registered: 1-2010 Posted From: 12.68.225.234
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 05, 2011 - 1:22 am: | |
I have the oppisite problem. Mine buzzed all the time even at 120 psi. But it was the same fix ,I tapped on it with a hammer and now it doesnt buzz at 120psi or 20psi. OK it was a little more than a tap. |
Iver (Mciv)
Post Number: 45 Registered: 11-2006 Posted From: 70.69.131.252
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 05, 2011 - 4:05 am: | |
"OK it was a little more than a tap." Good one!! Still chuckling..... |
Post Number: 1268 Registered: 11-2005 Posted From: 75.121.203.118
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, March 05, 2011 - 7:46 pm: | |
I hate buzzers, they are the worst sound possible (Probably by design). I plan to replace my 4107 buzzer by a big red light as I have all my others. |
Brian Evans (Bevans6)
Post Number: 18 Registered: 5-2009 Posted From: 65.92.54.2
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 06, 2011 - 7:37 am: | |
An audible low air alarm is a remarkably important safety device. Here, you won't pass a safety inspection without one. Brian |
Post Number: 2040 Registered: 12-2000 Posted From: 174.89.173.81
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 06, 2011 - 9:37 am: | |
Best to check your local jurisdictions nitty gritty legal writings. Many are worded such that a visual warning to the driver is all that is prescribed. Others will say it one place that way, and then a catch all that any equipped safety device must be working will be embedded elsewhere. So, be sure to remove the unused pieces? Aren't lawyers wonderful? Anyhow, a deaf driver can't determine whether the buzzer is functioning, and won't be warned by it. Be sure that big red light you put in is placed such that there is no time you have it hidden behind the wheel or your arms while driving, and is high enough to be well inside your vertical peripheral vision while looking down the road on a sunny day. You figure, in the old trucks of days gone by, a young driver might hear a buzzer over the racket, an older one surely wouldn't. Hearing loss amongst the grizzled veterans of the road was inevitable. There's a lot of good come out of health and safety legislation, and the young pups have no clue what they are taking for granted today in their occupations. Sometimes ignorance IS bliss!!! happy coaching! buswarrior |
Post Number: 11 Registered: 1-2006 Posted From: 204.112.248.100
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, March 17, 2011 - 6:27 pm: | |
Thanks for the input ... Ended up putting a new one in so no worries if stopped by DOT. |
