4104 drip rail Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2001 » April 2001 » 4104 drip rail « Previous Next »
Bud Shelly (24.69.61.123)
Posted on Wednesday, April 11, 2001 - 1:57 pm:
i am blanking out a couple windows on a 4104 and want to slide the new skin under the drip rail. how do you remove the drip rail? Or do you have any better suggestions
Jim Stacy (12.87.101.209)
Posted on Wednesday, April 11, 2001 - 10:04 pm:
I removed the entire drip rail using a VERY sharp chisel (reground like a wood plane blade) to cut the rivet heads. Then just drive out shank, slide new metal under roof panel, drill and re-rivet. Don't forget to seal joint. I used a good brand of latex (paintable).
