Donnie Daugherty (Dr_detroit)
Registered Member Username: Dr_detroit
Post Number: 16 Registered: 3-2008 Posted From: 98.145.193.168
Rating:  Votes: 1 (Vote!) | Posted on Saturday, March 12, 2011 - 12:20 am: | |
Jerry, My 4106 has been converted to a dry air cleaner assembly by the previous owner after an engine overhaul that was attributed to "Severe Dusting" (Mechanic's term on paper work). The filter assembly used is a Donaldson EBA112078 unit that was installed in the upper section of the engine compartment and gets air from the original air inlet section of the rear of the coach. I will attach a pic and show you how it is installed.
