Peter Broadribb (Madbrit) (65.37.89.249)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 15, 2003 - 9:34 pm: | |
Does anyone have any imput.......... I have found an Allison HT 740 in an 1978 FireTruck behind an 8v71. Only has 48K miles. It is in Georgia and shows bad rusting around the wheel wells. Was running before they removed some parts from the Fire equipment and stripped off the cab front area. Any concerns, thoughts, comments? Peter. |
Tony (64.215.196.168)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 15, 2003 - 9:52 pm: | |
Peter You get the Transmission and I will get the Engine that will fit In my MCI-7 the one In there smokes and according to my DDmanual that 8V71 In a FireTruck has either 370 or 400 HP. I would have bid on It but I am 3 states north of It Tony |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 15, 2003 - 9:53 pm: | |
Peter You get the Transmission and I will get the Engine that will fit In my MCI-7 the one In there smokes and according to my DDmanual that 8V71 In a FireTruck has either 370 or 400 HP. I would have bid on It but I am 3 states north of It, and we have snow here now. Tony |
BrianMCI96A3 (69.34.171.174)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 15, 2003 - 10:45 pm: | |
For my money 48k is a walk in the park for a HT740. Fire Departments maintain their equipment meticulously and they have probably the strictest Preventative Maintenance Program of virtually any governmental agency. I'd have to think the Allison is in fine shape. Pull the dipstick, I'd bet the Tranny fluid will be cherry red and smell fresh. Realistically, unless you can hear it run and move under it's own power, it is, as a friend of mine would say, "a pig in a poke". BUT, I wouldn't hesitate in the least... UNLESS the tranny fluid smells burned compared to fresh, and the fluid is brown. If the tranny was a really good deal,I might buy it even so... I know you can find good deals, and some have mentioned $2500 or less for one, but I'd bet for the most part THOSE trannys would have a SIGNIFICANT amount more miles than that tranny has. Brian |
J.L.Vickers (209.34.15.19)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 8:58 am: | |
If it's a fire truck remember it's not how many miles but hours it has on it. Fire Trucks sit at the fire scene and run for some time pumping water and what ever else they are required to do. So get a oil sample on the engine and transmission oil's send them out for testing. If the oil's check normal then perhaps go for it. JLV |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 12:27 pm: | |
Peter, Let me tell you what little I know about used fire engines. I have a little experience with them, with a fireman in the family and one of my buddies collects used aparatus. Fire departments retire equipment LONG before it has reached anything near what could be considered end of life in any other line of work. My buddy picks up engines that average $1,000 - $2,000 in price. Some much less. many have virtually new drivetrains in them in terms of mileage. I have always thought that would be a great source, but I don't have the heart to cut up a fire engine. Also, isn't the MT740 a T drive, while an MCI is V drive? I don't know, everything I do know about MCI's I've learned from this list. Edit: Sorry, Tony is asking about the engine not the trans--I'm going to have some more coffee. Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 12:34 pm: | |
Gary, The MCI is a T drive, as is the 740 Allison. However my MCI is now a Freightliner FLD 120 which is also a T drive, but from the other end. Don't worry about some of the fire engines, they are often rotten with rust or have the water tank rusted out. That in itself will retire the truck as often it is impossible to repair it due to the way they are constructed. Peter. |
Tony (64.215.196.155)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 12:41 pm: | |
Gary The MT doesn't come In a 740,and the V drive configuration Is the GM, Flex,most all of the city buses, these Transmissions below are all T Drive with the exception of V 730 V 731 V 731RH VR 731 VR 731RH They are all V drive above this line -------------------------------------------------- Transmissions by Series Sales and Service: 1000 Series™ 2000 Series™ 2400 Series™ 2000MH 3000MH 4000MH AT 545 B 300 B 400 B 500 EVS DP 8000 HD 4060 HD 4560 M 5610 M 6610 M 9600 MD 3060 MD 3066 MD 3560 MT 643 MT 653DR S 5610 S 6610 S 9600 S 9800 Service Support: AT 1542 AT 1545 AT 542 AT 542NFE AT 542NSE AT 542R CL(B)T 5640-4 CL(B)T 5961 CL(B)T 5963 CL(B)T 6061 CL(B)T 6063 CL(B)T 6063-10 CL(B)T 9681 CL(B)T 750 CL(B)T 754 CL(B)T 755 CRT 3321 CRT 3331 CRT 3531 CRT 3630 CRT 5530 CRT 5630 CRT 5631 CRT 5643 CRT 7000 DP 8962 HD 4070 HT 740 HT 741 HT 746 HT 747 HT 748 HT 750DR HT 754CR HT 755CR HT 755DR M - (Marine) MD 3070 MH - (Marine) MT 647 MT 648 MT 654CR Back To Top |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 1:20 pm: | |
Tony, He did say HT, not MT anyway (Damn Decaf!) MCI's are T-Drive? Like My bird? Anyone care to send a pic of an engine compartment? I'm curious. My buddy Jim, who collect fire engines--90% of them could be returned to service with a minimum of work. But we ARE on the west coast. He has one unit that goes back to the teens. I got to steer tiller once on one of his Hook&ladders. He has one, that was sometime in it's life "Upgraded" from a Gas v8 to an 8V71. Now that one is a hoot to drive, you either start out at an idle, or floorboarded. Very difficult to get moving anywhere in between. Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 3:42 pm: | |
Yes, Gary MCI's are a T-Drive... what particularly would you like to see of the engine compartment? Brian |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 4:11 pm: | |
Blatant Curiousity. I was just wondering how close it was to my Bluebird. Just a straight-on shot of an engine compartment, or if you know where one's posted on the web, that'd be cool. I was operating under the impression that there was no similarity between a Bluebird and MCIs. Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 5:40 pm: | |
Why Gary, I'm surprized at you, I'd think you realize that the main similarity between them is: they are both quality made coaches (grin)! Are you familiar with Craig Shepard's bus page? There are some pictures on his site of the rear of his MC-9 when he repaired his radiators and squirrel cages. Actually his site might be benificial to a lot of people, he's done some very cool things and taken pictures of most of it. Brian |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 6:36 pm: | |
I actually have his site bookmarked. Craig is incredibly meticulous. Cool! I see the engine location in the section for Radiators and Blowers. Are these Unibodies? The BB is not of course. I see a repower ahead someday and I was wondering what possible donors were available. Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 8:29 pm: | |
Monocoque if you please kind Sir, Unit Construction, if you will! Alright, yeah, its a Unibody (grin). Did you get all the way down to the pictures of the wide open engine bay? Brian |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 8:48 pm: | |
I don't say the "M" word. It's my own personal protest against the Frenchies. I looked around--all I saw was the Radiator/Blower section. I'm afraid I'm working on a couple of "War and Peace" documents and I haven't had much time for searching. If you can give me a hint as to what scetion the "Wide-Open" engine bay is in, that would be helpful. I'm particularly interested in the engine cradle layout and how the Trans -> Axle interface looks. Thanks, Gary |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 16, 2003 - 9:17 pm: | |
Ah, I see, that's what I meant earlier when I asked what particular section...In the radiator blower section almost at the end, it shows Craig's engine bay minus all the exterior skin from the back though. Maybe this weekend I'll take a shot or two of my engine bay, one through the access hatch, one of the cradle. Brian |
