Post Number: 597 Registered: 10-2003 Posted From: 99.122.63.218
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, March 27, 2011 - 9:45 am: | |
Jim, On my Flx I have a 4 cylinder diesel generator in the AC bay which affords it lots of air circulation this is right behind the drivers front and no overloading the axle; I'm not sure if the later ones are the same. Also on mine the bus AC was origionally powered by a separate gasoline engine so there is a separate origional gas tank in the rear radiator side that is now used to carry my generator diesel. If yours is the same you might want to consider using the existing tank because it already has hard fuel lines running up to the AC bay anyway and yo never have to worry about running your main tank dry with the gen. |
