Closed: New threads not accepted on this page |
Thread |
Last Poster |
Posts |
Pages |
Last Post |
  | 6V92TA radiator fan drive system filter | duane | 2 | 1 | 8-30-04 10:19 pm |
  | Towing Capability | Mark Radius | 11 | 1 | 8-30-04 10:45 pm |
  | Anyone we know? | Johnny | 3 | 1 | 8-29-04 7:36 pm |
  | 4106 Exhaust Manifold Failure | joe | 7 | 1 | 8-29-04 7:23 pm |
  | Fast Idle rpm? | Henry R. Bergman, Jr | 2 | 1 | 8-28-04 3:01 pm |
  | Coach USA drivers rate their coaches. | John Rigby | 10 | 1 | 8-28-04 4:52 pm |
  | 9:43 Got Him! | TWO DOGS | 11 | 1 | 8-28-04 9:36 pm |
  | MC9 24 volt circuit | John that newguy | 21 | 1 | 8-31-04 10:24 am |
  | Rumor of Fuel Taxes..... | John that newguy | 5 | 1 | 8-28-04 8:14 am |
  | MoreOT: WhatAToad | S.M. Heath | 11 | 1 | 8-28-04 3:22 am |
  | Fishbowl: Road Heat rebuild/ home-brew | FishbowlBrian | 15 | 1 | 8-28-04 1:42 pm |
  | Creating a Fishbowl/Newlook Group? | Ian Giffin | 12 | 1 | 8-27-04 5:21 pm |
  | Wiring diagram for onan genset | Craig Smith | 12 | 1 | 8-28-04 7:40 am |
  | How many gallons | Bob Baldwin | 10 | 1 | 8-28-04 2:18 am |
  | Toilet Fill-up | ChuckMC9 | 6 | 1 | 8-25-04 5:29 pm |
  | Access hatch | S.M. Heath | 23 | 1 | 8-28-04 3:44 am |
  | The Bus Pages | Jack In KC | 5 | 1 | 8-25-04 5:40 pm |
  | Retreads?? | Johnny | 10 | 1 | 8-26-04 12:00 am |
  | In Response to Michael Lewis | Michael Lewis | 2 | 1 | 8-24-04 12:13 am |
  | More fun! (OT) | Mark R. Obtinario | 13 | 1 | 8-26-04 10:10 am |
  | Corrupted Governors | Robert Wayne Aviles | 16 | 1 | 8-27-04 8:09 pm |
  | Tire help request | Tom Caffrey | 13 | 1 | 8-26-04 10:35 pm |
  | 4104 rear factory door. | Doug | 19 | 1 | 8-25-04 8:18 pm |
  | Crazy Battery Questions | Marc Bourget | 6 | 1 | 8-23-04 11:02 pm |
  | Pulling out Tomorrow | TWO DOGS | 2 | 1 | 8-23-04 7:49 am |
  | Two Dogs' New Girlfriend - "Miss Busnut" - Advisory: Adult Oriented... | Gary McFarland | 45 | 1 | 8-25-04 10:45 am |
  | Regulator | Gary Carter | 10 | 1 | 8-23-04 12:37 am |
  | 50Amp Panel & neutrals | R.J.Bob Evans | 6 | 1 | 8-23-04 3:13 pm |
  | Shell Covering, STICKAFLEX or ??? | FAST FRED | 22 | 1 | 8-25-04 5:43 am |
  | OT: Vegetable Oil Powered | Niles | 6 | 1 | 8-24-04 5:39 pm |
  | Sanity check on plumbing tree | Jim Ashworth | 56 | 1 | 8-26-04 8:57 am |
  | How High? | Cliff | 12 | 1 | 8-24-04 8:08 pm |
  | Manual for a 4903 | J.L.Vickers | 4 | 1 | 8-22-04 8:58 pm |
  | Parked in Madison, Wisconsin | Kirby | 11 | 1 | 8-23-04 6:52 pm |
  | 4106 clutch problem | dgkurtz | 12 | 1 | 8-21-04 7:44 pm |
  | New Problems for DDEC2 start | Ace | 10 | 1 | 8-22-04 8:31 am |
  | Generator fuel lines? | BrianMCI96A3 | 4 | 1 | 8-20-04 10:28 am |
  | OK, I'm Totally Crazy | busone | 24 | 1 | 8-22-04 8:51 pm |
  | 8v92 will not start unless you put a shot of WD 40 | TWO DOGS | 11 | 1 | 8-20-04 10:18 pm |
  | Wheel well couch | James Maxwell | 7 | 1 | 8-19-04 11:26 pm |
  | Midwest Bus Nuts | Gary Carter | 5 | 1 | 8-20-04 1:33 pm |
  | Sound of Silence + insulating noise | FAST FRED | 10 | 1 | 8-22-04 5:25 am |
  | Weight Of GM 4905 ??? | Stephen Fessenden | 27 | 1 | 8-27-04 11:11 pm |
  | Off subject | Sojourner | 18 | 1 | 8-19-04 12:42 am |
  | Removing oil cooler | JImmci9 | 2 | 1 | 8-17-04 6:32 pm |
  | Window Air? | Dallas | 7 | 1 | 8-18-04 7:04 am |
  | Generator light on. Fixed! | Bob Baldwin | 1 | 1 | 8-17-04 3:55 pm |
  | Hurricane Charley Photos | John Dodge | 4 | 1 | 8-18-04 12:50 am |
  | Hurricane Charley Update | Jim-Bob | 7 | 1 | 8-18-04 12:22 pm |
  | Starting Engine | Niles | 8 | 1 | 8-21-04 11:48 pm |
  | And just as I was having fun! | John that newguy | 20 | 1 | 8-22-04 8:20 am |
  | Thanks for your consideration | Niles | 1 | 1 | 8-17-04 5:04 am |
  | Help with letting air out of suspension | Just a suggestion | 3 | 1 | 8-17-04 7:58 am |
  | Traded my seated MC8 for a semi-converted Fishbowl | Johnny | 15 | 1 | 8-20-04 12:49 am |
  | Removing anodizing -- what's the trick? | TWO DOGS | 27 | 1 | 8-20-04 11:44 pm |
  | Supertherm test | Dallas | 3 | 1 | 8-17-04 4:13 pm |
  | Life sucks... then you realize you have an old bus | TWO DOGS | 13 | 1 | 8-20-04 4:17 pm |
  | Venting Appliances (Propane) Cut the Coach? | TWO DOGS | 9 | 1 | 8-16-04 2:03 pm |
  | Fuel filters- how often do you change? | LHD | 18 | 1 | 8-18-04 9:02 pm |
  | DD6V92 doesn't stay running. | Art Gill | 8 | 1 | 8-16-04 5:14 pm |
  | Satellite Antenna | Dean Stoops | 37 | 1 | 8-17-04 11:11 am |
  | Supertherm - Jerry Liebler | John that newguy | 46 | 1 | 8-19-04 9:37 am |
  | Aux battery charging question | Bill | 5 | 1 | 8-20-04 8:21 am |
  | Need good resource for designing bus Electrical system | ChuckMC9 | 17 | 1 | 8-19-04 11:44 am |
  | LCD television on modified sine-wave | Gary McFarland | 11 | 1 | 8-18-04 7:55 am |
  | Hurricane | Stephen Fessenden | 13 | 1 | 8-16-04 8:51 pm |
  | Propane Generator? | John that newguy | 18 | 1 | 8-16-04 9:12 pm |
  | Air bags | BrianMCI96A3 | 13 | 1 | 8-15-04 10:36 am |
  | Time to go busin | John that newguy | 12 | 1 | 8-13-04 9:48 pm |
  | Modified Sine Wave Inverters | Johnny | 16 | 1 | 8-15-04 7:15 pm |
  | Anyone Do The Oshkosh Air Show? | Phil | 2 | 1 | 8-12-04 3:53 pm |
  | Engine performance when climbing | John Rigby | 29 | 1 | 8-15-04 9:32 am |
  | Raising the roof | Paul Wiest | 3 | 1 | 8-12-04 7:38 pm |
  | 73 05 Eagle Radiator Misting information request | Neil | 4 | 1 | 8-12-04 1:51 pm |
  | Kerosene / 110v Refrigerator | John that newguy | 12 | 1 | 8-14-04 11:53 pm |
  | 4104 Rear Access Panel (Manifold) | Jim-Bob | 4 | 1 | 8-16-04 10:53 pm |
  | Help! I'm a newbie! MCI 8? | TWO DOGS | 11 | 1 | 8-16-04 9:19 pm |
  | Detroit 6-92 fuel lines | Jim Ashworth | 3 | 1 | 8-12-04 7:33 am |
  | Park brake | Buswarrior | 9 | 1 | 8-18-04 10:47 pm |
  | 4104 original air conditioner | dounan | 1 | 1 | 8-11-04 5:01 pm |
  | Generator cooling long question | Ace | 7 | 1 | 8-11-04 10:07 pm |
  | Camping World's built in vacuums (or any others?) | DrivingMissLazy | 7 | 1 | 8-12-04 8:42 am |
  | Dual Gensets? | Abajaba | 16 | 1 | 8-12-04 10:58 pm |
  | Water in 4106 air cleaners | John that newguy | 5 | 1 | 8-11-04 9:26 am |
  | I will camp in my bus by the end of January! (progress update) | Darryl | 2 | 1 | 8-10-04 11:45 pm |
  | Doing It Your Way | R.J.Bob Evans | 7 | 1 | 8-10-04 6:51 pm |
  | Help - generator light! | FAST FRED | 7 | 1 | 8-13-04 6:47 am |
  | Front end shake on a 4104 | John Rigby | 10 | 1 | 8-13-04 9:27 am |
  | Oil coolers | edwin b | 1 | 1 | 8-09-04 4:30 pm |
  | 4106 electrical problem | John that newguy | 14 | 1 | 8-12-04 6:15 pm |
  | Air conditioning options | Jerry Liebler | 2 | 1 | 8-09-04 9:33 pm |
  | Detroit Diesel 6-92 problem | guy bouchard | 11 | 1 | 8-09-04 6:32 pm |
  | Fibreglass and ABS Plastic | joe | 6 | 1 | 8-14-04 10:06 pm |
  | Oil cup atop air intake | Bulldogie | 9 | 1 | 8-09-04 6:33 pm |
  | Old bus gods are at it again | John Rigby | 4 | 1 | 8-08-04 1:54 pm |
  | DD gen set | DrivingMissLazy | 14 | 1 | 8-12-04 10:23 am |
  | Is this a smart place to be playing jacks? | Johnny | 7 | 1 | 8-10-04 8:16 pm |
  | Accelerator cable sticking 4106 | Tom Caffrey | 8 | 1 | 8-10-04 11:15 pm |
  | Series 60 engine mounts for a conversion | derek_l | 9 | 1 | 8-10-04 4:41 pm |
  | 4104 rear access panel (manifold) | John that newguy | 5 | 1 | 8-07-04 7:48 am |
  | Jake brake | Gary McFarland | 20 | 1 | 8-10-04 9:29 pm |
  | Transmission cooler - size and location ideas | AL4106 | 8 | 1 | 8-09-04 6:26 pm |
  | Wiring harness and the mc9 luggage rack | ChuckMC9 | 39 | 1 | 8-12-04 10:31 pm |
  | Anyone in the Portland/Vancouver area? | Lorin David McCleary | 6 | 1 | 8-07-04 2:22 pm |
  | Nice people out there! | TWO DOGS | 16 | 1 | 8-07-04 12:02 pm |
  | Thanks Ian! | Deacon | 1 | 1 | 8-03-04 5:29 pm |
  | "Simple Conversion"-Was Luggage Rack Removal | Gary McFarland | 9 | 1 | 8-09-04 1:39 am |
  | Generator Fuel Tap | John that newguy | 10 | 1 | 8-07-04 7:28 am |
  | Advice on filling in side double doors and stairwell on MC5c | Gary McFarland | 9 | 1 | 8-04-04 12:39 pm |
  | Will mc7 door fit mc5a? | Dallas Farnworth | 4 | 1 | 8-03-04 10:47 am |
  | ICC lights | Jayjay | 14 | 1 | 8-04-04 9:49 pm |
  | Luggage rack removal | TWO DOGS | 12 | 1 | 8-03-04 7:49 pm |
  | Awnings | David & Lorna Schins | 3 | 1 | 8-03-04 8:57 am |
  | Stepwell Cover What's Your Solution? | John Rigby | 14 | 1 | 8-07-04 8:03 am |
  | DD3 Brake Woes (Long) | BrianBrownMC8 | 27 | 1 | 8-12-04 12:22 am |
  | Tropical Storm "Alex" Travel Alert | John Finn | 1 | 1 | 8-02-04 9:49 am |
  | Mobile Command Post Conversion Questions | Buswarrior | 13 | 1 | 8-04-04 9:13 pm |
  | Gauges/ stupid question | TWO DOGS | 8 | 1 | 8-02-04 7:34 pm |
  | Don't Look Ethel | Robert Wood | 16 | 1 | 8-02-04 12:30 pm |
  | MC9 Door Lever Bolt Problem | TWO DOGS | 3 | 1 | 8-01-04 5:01 pm |
  | 4106 generator light stays on | Tom Caffrey | 6 | 1 | 8-05-04 2:15 am |
  | Penisula windows | John that newguy | 4 | 1 | 8-05-04 8:56 am |
  | Smoke Puffs | don | 12 | 1 | 8-01-04 4:57 pm |
  | Onan problems | dwight | 11 | 1 | 8-03-04 1:20 pm |
  | Over The Hill | Ace | 21 | 1 | 8-04-04 8:12 pm |
  | DVD, CD, AM, FM car radios cheap now | FAST FRED | 16 | 1 | 8-14-04 5:45 am |
  | AC options | TomC | 8 | 1 | 8-07-04 1:39 am |
  | Paint for Battery compartment? | Bill 4104 4032 | 13 | 1 | 8-04-04 7:59 pm |
  | Spicer Woes | Tom Caffrey | 4 | 1 | 8-05-04 12:51 am |
  | Starting Batteries | Johnny | 7 | 1 | 8-14-04 12:07 am |
  | OMG Bought a 1980 MC5..Need some info on it Please. | Tom Caffrey | 12 | 1 | 8-04-04 11:07 pm |
  | The Ultimate in Intermodal Transport? | Tom Caffrey | 9 | 1 | 8-04-04 10:52 pm |
  | Electric Motor Problem - slightly OT | Tom Caffrey | 11 | 1 | 8-04-04 10:31 pm |
  | 671 idles high at 1200rpm? | John Rigby | 20 | 1 | 8-01-04 6:15 pm |
  | Need california bus to take class B noncommercial test | John that newguy | 58 | 1 | 8-01-04 10:49 am |
  | Diesel Gen Fuel connections | Tom Caffrey | 15 | 1 | 8-03-04 9:53 pm |
  | LED resistor position? | mrpuppy | 22 | 1 | 8-01-04 5:28 pm |
  | Two Dogs' mice | TWO DOGS | 10 | 1 | 8-07-04 3:49 pm |
  | GPS unit for laptop, DeLorme? | Tom Caffrey | 10 | 1 | 8-02-04 10:37 pm |
  | Webasto, Aqua Hot, Pro Heat: Best? | Tom Caffrey | 18 | 1 | 8-06-04 2:51 am |
  | Changing alternators on MC8 | Tom Caffrey | 8 | 1 | 8-02-04 1:47 am |
  | Engine rebuild time? | Gary Carter | 9 | 1 | 8-02-04 1:22 pm |
  | Generator out need advice on alternator | Tom Caffrey | 25 | 1 | 8-01-04 7:00 pm |
  | Back from BUS'N USA | Tom Caffrey | 6 | 1 | 8-01-04 4:31 pm |
  | Factory Air? | gillig-dan | 20 | 1 | 8-09-04 1:46 pm |
