Tire pressure monitors Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » May 2011 » Tire pressure monitors « Previous Next »
Kenneth Hintermeister (Barbwire)
Username: Barbwire
Post Number: 19
Posted From: 205.188.116.203
Posted on Wednesday, April 20, 2011 - 9:58 am:
Hey Sam RV saftyman, I've got 2 monitors with dead batterys. (Pressure Pro) What now?
Username: Jackconrad
Post Number: 1399
Posted From: 75.203.234.236
Posted on Wednesday, April 20, 2011 - 3:38 pm:
Monitors or wheel sensors? If it is wheel sensors, you will have to send them in and get replacements. I don't think there are any batteries in the monitor (the part that is on the dash). Jack
Username: Barbwire
Post Number: 20
Posted on Wednesday, April 20, 2011 - 6:04 pm:
I stand corrected, Wheel sensors
Jim Shepherd (Rv_safetyman)
Username: Rv_safetyman
Post Number: 330
Posted From: 75.212.114.129
Posted on Thursday, April 21, 2011 - 9:30 am:
Kenneth, the sensors can be sent to:
http://www.advantagepressurepro.com/
They will exchange them for $35.
Before you spend the money, I would verify that the sensor is bad. They should last at least 5 years. My first set just died after 6 years and three months and I leave them on all the time.
You can test them by moving them one at a time to the front wheel and look on your monitor. That sensor, if it works, will show the pressure at the original position (the monitor will think it is on the old tire position).
Jim Shepherd
Evergreen, CO
’85 Eagle 10/Series 60/Eaton AutoShift 10 speed transmission
Somewhere between a tin tent and a finished product
Bus Project details: http://www.rvsafetysystems.com/busproject.htm
Blog: http://rvsafetyman.blogspot.com/
Username: Dougthebonifiedbusnut
Post Number: 158
Posted From: 98.216.80.83
Posted on Thursday, April 21, 2011 - 9:28 pm:
Sorry guys but 35 years in the heavy truckin business, never had a monitor never needed one. My crowns weight is 26k now I put 90 lbs in the tires, check them once a year and am good to go. A bleepin waist of money if you ask me but if you got it to spend then go for it.
Username: Timb
Post Number: 605
Posted From: 66.165.176.62
Posted on Friday, April 22, 2011 - 9:26 am:
I don't have the experience Doug has but all I have done is check them each time I take the bus out. In the last 3 years since I installed new tires the pressures have never changed
Username: Ace
Post Number: 1213
Posted From: 99.205.238.20
Posted on Friday, April 22, 2011 - 9:27 am:
Ive had mine quite a while and they have given me no problems. Could be because they are still In the box they came in. More than I can say about the vms silverleaf!
Post Number: 1348
Posted From: 71.55.178.71
Posted on Friday, April 22, 2011 - 9:36 am:
CHESSIE!!! Ace is at it again lol they will never wear out that way lol
Gomer
Username: Ace
Post Number: 1214
Posted From: 184.213.93.222
Posted on Friday, April 22, 2011 - 12:50 pm:
Gomer, just telling it like it is!
Username: Gusc
Post Number: 1308
Posted From: 173.202.20.202
Posted on Friday, April 22, 2011 - 7:36 pm:
Douglas,
I admire your optimism. I had a continuous problem with leaking valve cores on my 4104 for about the past three years.
None lately though. I`still don't know what happened because in my in my 60 yrs+ of being a shade tree mechanic I never had that many fail in total?
Username: Chessie4905
Post Number: 2068
Posted From: 71.58.71.157
Posted on Friday, April 22, 2011 - 10:21 pm:
Since the price of fuel prohibits most of us from going far on the road for now, Leaving them in the box may be best. He may need new batteries for them when and if he installs them?
Post Number: 1401
Posted From: 75.224.45.221
Posted on Saturday, April 23, 2011 - 7:42 am:
Jim told me the sensors only transmit when installed and pressure is in the tire. Removing them when not travaling will extend bsttery life. Don't know what shelf life would be. We have never removed ours, except when we took the front sensors off the Grand Cherokee to use on our golf cart trailer when towing it.
I was told bt another PressurePro dealer that the small LED in the lower right coner of the monitor would light up if you had a low sensor battery as well as the position indicator of that sensor. Ours are 6 or 7 years old and still working great. Jack
jerry garrido (Uemjg)
Username: Uemjg
Post Number: 43
Posted From: 70.244.34.238
Posted on Wednesday, April 27, 2011 - 10:48 pm:
How much for the system?
George Martinez (Foohorse)
Username: Foohorse
Post Number: 562
Posted From: 69.171.161.47
Posted on Wednesday, May 25, 2011 - 11:23 pm:
I`still don't know what happened because in my in my 60 yrs+ of being a shade tree mechanic I never had that many fail in total? Doug perhaps it's because now they like everything else is made in China. I see valve stems rot and crumble all the time and decades past it seemed you never heard of them failing.
