Tom Phillips (Fortyniner)
Registered Member Username: Fortyniner
Post Number: 37 Registered: 2-2010 Posted From: 66.93.216.253
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 21, 2011 - 8:50 pm: | |
How do these motor mounts look? The 4106 Im messing with has a lot of vibration on fastidle. Dont see any place obvious that might cause it. Tom P.
Post Number: 501 Registered: 7-2004 Posted From: 98.20.55.33
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 21, 2011 - 9:46 pm: | |
To me the mounts look good. If you have a vibration, look into having the rack run. you may have a bad injector or two. or three. Besides, I don't think Detroits run well when wearing the Caterpillar Halloween costumes. |
Post Number: 1345 Registered: 3-2007 Posted From: 71.55.178.71
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 21, 2011 - 9:56 pm: | |
Tom; I had an 06 and found that from time to time I would have to check the bell housing for loose bolts. Also you may have a flywheel coming loose. Gomer |
Post Number: 38 Registered: 2-2010 Posted From: 66.93.216.253
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, April 21, 2011 - 11:41 pm: | |
Great, first its a caterpillar now it has loose nuts. Running the rack is easier than checking flywheel so I guess Ill start there. Thanks ! |
Post Number: 2073 Registered: 12-2000 Posted From: 174.91.144.16
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 22, 2011 - 6:42 am: | |
Fortyniner, I do believe that you have got this board and its inmates well figured out! happy coaching! buswarrior |
Post Number: 1347 Registered: 3-2007 Posted From: 71.55.178.71
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 22, 2011 - 8:47 am: | |
Tom You are fitting in just perfect LOL GOOD ONE Gomer |
Bill Gerrie (Bill_gerrie)
Post Number: 493 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, April 22, 2011 - 10:58 am: | |
Tom Motor mounts are generally good unless they get oil soaked. Dal is probably right on when he says to look for a bad injector and maybe the halloween costume has a lot to do with it as well. Bill |
Brandon Merritt (Brando4905)
Registered Member Username: Brando4905
Post Number: 37 Registered: 3-2009 Posted From: 50.55.221.225
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, April 26, 2011 - 9:20 am: | |
Tom, Check the bulkhead for cracks also, had mine repaired recently and the vibes at fast idle went away. |
