Shaved door handles????? Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » February 2004 » Shaved door handles????? « Previous Next »
Posted on Sunday, February 01, 2004 - 12:40 pm:
Watching TV I had a thought. Anybody ever thought about putting a "shaved door handle" kit on a bus. You could either get a aftermarket setup or build one of your own without much trouble I think. Just a thought what do ya'll think.
Bus Jock (4.41.169.103)
Posted on Sunday, February 01, 2004 - 3:45 pm:
Perhaps I have been sleeping too long.
What the heck is a "Shaved Door Handle" ????
Jock
Posted on Sunday, February 01, 2004 - 4:01 pm:
A lot of hot rod and street rod guys take the door handles off their rides and replace them with an electric seloniod to open the door. It lets you have clean lines down the side of your rig as well as (and this is just my opinion) a little more security. Of course you need to install a cable somewhere out of sight just in case you lose power and the selonoid fails.
jim mci-9 (209.240.205.60)
Posted on Sunday, February 01, 2004 - 4:06 pm:
most of the newer eagles and mci's have an electric door opener....a toggle switch righ by the front tire...
Posted on Sunday, February 01, 2004 - 4:48 pm:
Has anyone thought about or tried one on an older coach.
Jim & Linda Callaghan (Jimc) (169.207.88.236)
Posted on Sunday, February 01, 2004 - 5:33 pm:
I have shaved handles on my 4106, I can't take credit for it though, the previous owner / builder put it in.
I have to admit it is pretty slick, I havn't taken the door apart to look yet, but he said that he used a GM trunk release mechanism. There is a button next to the door that looks like a door bell to activate the unit.
Jim Callaghan
Posted on Sunday, February 01, 2004 - 5:49 pm:
How do lock it Jim? With an electric one it's no problem but how does yours work?
James Maxwell (Jmaxwell) (66.81.45.48)
Posted on Sunday, February 01, 2004 - 10:46 pm:
I'm going that route w/my Jetliner. I liked the air door but had concerns for how to lock it when the air is gone or when I'm parked. I did not want to install latch mechanisms with handles since it will have to unlock swiftly when I hit the door button to open.Will use 2 solenoids with cam mechanisms under the door frame and tie them into the electrical part of the air-override built in. Now all I have to do is build all this.
BrianMCI96A3 (69.34.169.42)
Posted on Sunday, February 01, 2004 - 11:52 pm:
Only one problem, you should have some sort of manual over-ride, unless you want to be locked out of your coach one day, maybe in the middle of the night if the solenoid fails.
Brian
David & Lorna Schinske (Davidschinske) (67.216.90.30)
Posted on Monday, February 02, 2004 - 8:50 am:
Of course it will be the middle of the night when it fails... Or it will be pouring rain or any of a number (or combination) of "Murphy's Law" scenerios. It least that is my experience.
"Could be worse... Could be raining"
Lorna
James Maxwell (Jmaxwell) (66.81.212.191)
Posted on Monday, February 02, 2004 - 4:19 pm:
It is raining--3 days now and at least 1 more to go. Yes, I will provide for a purely mechanical over-ride of the electric latches. The air door has wedge bars that engage when it closes under air pressure--the door lifts about 1" once it is in the closed position. Then, as it opens it lowers before swinging open. There is the problem w/ the air, or lack of air more precisely. The door is in an unlatched position without air pressure. I'm also considering just keeping the air system as is and merely hooking air supply from the aux. air compressor I installed. That may prove to be just as effective and simpler to do but then I have to leave the aux. compressor on-line while parked. Oh, all these decisions and in the midst of a downpour. My ideas are getting soggy!
Adame (129.82.53.199)
Posted on Monday, February 02, 2004 - 10:05 pm:
My '48 Flxible Clipper has a hidden opener from the factory. The Clipper style dates back to the streamlined era of the late thirtys. Maybe that's where the hot rodders saw it first.
H3Jim (68.105.103.139)
Posted on Thursday, February 05, 2004 - 7:38 am:
Lorna,
"could be worse, could be raining"
Loved that movie, still a classic. Thanks for the reference.
bulldogie (69.4.194.147)
Posted on Sunday, February 08, 2004 - 10:33 am:
Had a bus man tell me to just remove the handle and then carry it in the bus, when you need to open it you can insert the handle and volia your in. Wife smiled and said yes, and you will lay it down and forget where you put it and ask me to find it hehehe
