Air problem Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2011 » May 2011 » Air problem « Previous Next »
al olszewski (Happydays)
Username: Happydays
Post Number: 22
Posted From: 75.241.114.30
Posted on Thursday, May 26, 2011 - 6:06 am:
my bus has setting over winter.When I went to start it today and air come up fast 150 lbs brakes locked up and air bags don't seem to go up. Horn like sound comes from side 79 tmc 871 det......what went wrong???? If some one could help on this it would be great.
Brian Evans (Bevans6)
Username: Bevans6
Post Number: 36
Posted From: 184.151.127.167
Posted on Thursday, May 26, 2011 - 6:13 am:
sounds like you have a governor issue and the pressure is rising until the pressure relief valve pops off at 150 PSI. That would be the horn-like sound. The governor reads pressure from the dry tank, which also feeds the brakes. Not sure about the brakes locked up or the suspensions, only thing that comes to mind is the pressure protection valve may be stuck keeping air from passing into the rest of the system, including the emergency tank so you can't release the DD3's (if you have DD3's) or the accessory system so you can air up the suspension.
Brian
Username: Gusc
Post Number: 1323
Posted From: 173.202.1.140
Posted on Thursday, May 26, 2011 - 8:48 pm:
My pressure went up to 150 psi when my compressor governor failed, as Brian says.
Post Number: 2087
Posted From: 174.91.140.216
Posted on Saturday, May 28, 2011 - 8:56 am:
Happydays, do you have a unit number for your coach so we can see if one of us has the air schematic?
Interesting problem, no parking brake release, no air suspension, and 150 lbs of air showing on the gauge?
I'm thinking a strategic blockage, governor isn't sensing a pressure to cut-out, and with no air there, no air for the rest.
This horn sound, from where, under the front, under the back, near what components?
Does you coach sit on the ground or a paved/poured surface?
