Post Number: 1147 Registered: 8-2006 Posted From: 74.33.60.241
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 14, 2011 - 10:42 pm: | |
Dallas, I have a 4905a in the shop my question after looking at it for a week is there any way to remove the top head without removing the blower to me the GM looks like the engine needs to come to do anything lol forgot to tell you it has a 8v71 turbo engine piping everywhere (Message edited by luvrbus on June 14, 2011) |
Post Number: 1427 Registered: 3-2007 Posted From: 71.55.178.71
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 14, 2011 - 11:14 pm: | |
can I answer?? NOPE! Gomer |
Post Number: 1148 Registered: 8-2006 Posted From: 74.33.60.241
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, June 14, 2011 - 11:35 pm: | |
Sure you can Gomer any of you GM guys can give me advice Dallas is the only GM guy I knew here after working installing a set of Jakes on a 4106 in the last few days I have a whole new out look on you GM guys these things are a PITA to work on compared to a Eagle good luck |
Post Number: 593 Registered: 7-2004 Posted From: 75.91.197.132
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 15, 2011 - 5:17 am: | |
Clifford, I don't know about the turbo having to be removed, but it probably does. I've never had to remove the blower on the 8V, there is about 3-4 inches of clearance but you have to get the cherry picker as tight to the head as possible or you'll hit the lip of the tailgate opening. It does help to remove that silly coolant housing on the front of the engine, that thing will take up every bit of space. Good Luck! |
ned sanders (Uncle_ned)
Post Number: 104 Registered: 5-2005 Posted From: 184.39.28.244
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 15, 2011 - 10:29 am: | |
Clifford Call David at Davids Coach.828-874-6105 or Gene Russel at 828-863-2102. Both are great gm and detroit guys. and both like to talk buses uncle ned |
Post Number: 481 Registered: 12-2000 Posted From: 72.187.35.208
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 15, 2011 - 12:48 pm: | |
I think that back in the days of Greyhound revenue service, they would roll the whole engine cradle out for almost any maintenance. With the right tools and dolly, it was pretty easy. Perhaps not so poorly designed when you consider that. |
Post Number: 595 Registered: 7-2004 Posted From: 75.91.197.132
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 15, 2011 - 1:08 pm: | |
Len is correct... Trailways wrench twisters could actually remove and reinstall a power pack in a single shift and have the bus back on the road by he time the next shift came in. My PD4103 had a power pack swap in 1966 and according to the logs and W/O's I have for it, it took two guys 6 hours and 28 minutes from start to finish. The nice thing about being a mechanic back then is you didn't have to fuel the beast up, wash it, mop the interior or wash the windows when you were finished. |
Post Number: 782 Registered: 1-2009 Posted From: 72.211.145.15
Rating:  Votes: 1 (Vote!) | Posted on Wednesday, June 15, 2011 - 1:16 pm: | |
It sounds to me like your Woman has trained you correctly, does she know you snivel behind her back...? $100. from you & mums the word from me..! |
Post Number: 597 Registered: 7-2004 Posted From: 75.91.197.132
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, June 15, 2011 - 1:34 pm: | |
she already knows.... I not only snivel, I grovel too, usually right in front of her. |
Post Number: 1149 Registered: 8-2006 Posted From: 74.33.60.241
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 16, 2011 - 11:41 am: | |
That blower is to easy to remove I need all the room I can get for these old bones |
Post Number: 598 Registered: 7-2004 Posted From: 75.91.197.132
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 16, 2011 - 12:16 pm: | |
by all means, remove the blower, but you may still have a clearance issue with the tailgate. Just be careful. |
Post Number: 1549 Registered: 10-2006 Posted From: 76.194.80.141
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 17, 2011 - 2:01 pm: | |
I have a 4905a in the shop my question after looking at it for a week Not very much time and you can simply remove the engine. With Hound the complete R&R was done in 6-8 hours , with 2 experienced folks and the engine cradle handy. Lots easier to work on where you can get to stuff , and easier to upgrade to things like new hoses with out being double jointed. Being able to see what your doing , priceless! FF |
Post Number: 601 Registered: 7-2004 Posted From: 75.91.197.132
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 17, 2011 - 2:15 pm: | |
Again, Fred is right... it's so much easier to pull the whole power pack, do the work and push it back in. The time you take to remove the blower and reinstall it is about 20% of the time needed for a whole R&R. Thanks Fred, BTW, why are you in here so late this fine afternoon? |
Post Number: 518 Registered: 6-2004 Posted From: 66.38.159.33
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, June 17, 2011 - 10:05 pm: | |
so late this afternoon? Fred is probably taking a break from excercising those new S50 horses......got to break them in gently you know. |
Mike Eades (Mike4905)
Post Number: 210 Registered: 12-2000 Posted From: 70.126.183.226
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 18, 2011 - 1:16 pm: | |
I had a mechanic work on mine and he told it was less time to pull the engine. Eight bolts and a lot of fluids. hardest part was the drive shaft. He used a forklift with a chaine . whole unit came out in about seven hours. Now if you need to get into the top of your engine, there is an opening inside of your coach in the back that will let you get down near the top. Had a started rebuildt and told the mechanic to go that way and said no, he could do it with another machanic and a pipe. He changed his mine in hurry. |
Post Number: 1154 Registered: 8-2006 Posted From: 74.33.60.241
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 18, 2011 - 1:30 pm: | |
You would have to tear the bedroom apart to get to the hatch on this 4905A why people cover the hatches remains a mystery to me good luck |
Post Number: 602 Registered: 7-2004 Posted From: 75.91.197.132
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 18, 2011 - 1:44 pm: | |
Mike, Trying to remove a head through the access hole is a real PITA. I tried it twice, and just pulling the power pack was a whole lot less work. For me, pulling the head from the back isn't that difficult, but trying to explain how I do it is difficult in this flat forum. I am not articulate enough to explain what I mean in the proper terms. I would advise anyone that is doing heavy work to a transverse mount bus engine to just pull the power pack. Pulling the drive shaft isn't hard, just remove it from the spline as you go. |
Post Number: 1552 Registered: 10-2006 Posted From: 76.194.80.141
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 19, 2011 - 7:13 am: | |
Fred is probably taking a break from excercising those new S50 horses......got to break them in gently you know I Wish, there is a long way between "running" and usefull in a bus. Things like air lines , new power steering lines , water to the heaters/defroster . Batteries , start + house , a trace to run the air cond , and all the rest. Happily we did purchase a boat that can be towed by the VL. AS most know the Sportscar 4106 has limited tongue weight ability , so 6000 lb tows is a no,no. http://www.yachtworld.com/core/listing/pl_boat_detail.jsp?&units=Feet&id=2020355&lang=en&s lim=broker&&hosturl=northeastyachtsales&&ywo=northeastyachtsales& This is short enough to keep the total bus + trailer length under 65 ft , the state requirement in lots of states. For a diesel guy 3500rpm cruise is new , but Im told the 305 Chebby is fine with it. FF |
