Alarm Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » March 2004 » Alarm « Previous Next »
John Lawson (216.93.228.174)
Posted on Friday, March 12, 2004 - 12:54 pm:
I have a GMC 4107 and there is some sort of alarm going off by the battery box. Battery power is disconnected. Any ideas?
john w. roan (Chessie4905) (69.162.21.219)
Posted on Saturday, March 13, 2004 - 12:49 pm:
Maybe it means " THE BATTERY IS DISCONNECTED"....just kidding....Do you have a propane or carbon monoxide detector on the coach? How about a battery or propane refer?
Posted on Saturday, March 13, 2004 - 7:31 pm:
Could it be from a slow air leak back through a malfunctioning check valve?
Posted on Sunday, March 14, 2004 - 10:59 pm:
Thanks for the ideas John. When I could finally pull the bus out where I could get at it, the alarm turned out to be a low voltage alarm on an inverter that the previous owner had hooked up after the battery cut off switch.
