jr villanueva (Jrrockstar67)
Registered Member Username: Jrrockstar67
Post Number: 9 Registered: 2-2009 Posted From: 166.147.67.152
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 25, 2011 - 7:36 pm: | |
Hello fellow bus nuts, I am in desperate need of some help. My front ac unit is blowing cold but weak air. Heard of a failed capacitor could cause this problem, but do not know for sure. The temp has been over 98 degrees. I could use some suggestions on where to start. Thank you. |
Sean Welsh (Sean)
Post Number: 1263 Registered: 1-2003 Posted From: 67.142.130.25
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 25, 2011 - 8:55 pm: | |
I would start by measuring the voltage at the unit while it is running. -Sean http://OurOdyssey.BlogSpot.com |
George M. Todd (George_todd)
Post Number: 1246 Registered: 8-2006 Posted From: 99.37.28.23
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 25, 2011 - 10:39 pm: | |
JR, Sounds to me like the filter is dirty, a second guess would be bad fan bearings. There are actually two capacitors in most of these systems. One, or half of a dual capacitor, runs the fans, the other runs the compressor. If the capacitor is bad, the compressor and/or the fans won't run. |
Post Number: 10 Registered: 2-2009 Posted From: 166.147.65.194
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 25, 2011 - 11:29 pm: | |
Thanks for for the help,Ill try replacing them,you all are the best!!! |
Jaime Martinez (Jaime)
Registered Member Username: Jaime
Post Number: 18 Registered: 4-2009 Posted From: 72.201.203.164
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, June 25, 2011 - 11:58 pm: | |
My Coleman mach has high and low speeds you may want to check the thermostat and work the switch back and forth, if you have this feature. On my unit the only time it has blown slow is when the filter was dirty and the restriction caused the coils to freeze up. |
Post Number: 1161 Registered: 8-2006 Posted From: 74.33.60.241
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 9:50 am: | |
probably just needs a good cleaning my son's Cloeman AC's units will do that about every 5 years when they get dirty the filter system on those are not much let's a lot of dirt plug the coils good luck |
Post Number: 1540 Registered: 7-2006 Posted From: 97.214.138.39
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 2:34 pm: | |
Great looking coach, Jr... RCB |
Post Number: 11 Registered: 2-2009 Posted From: 69.15.129.202
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, June 30, 2011 - 2:49 pm: | |
THANKS GUYS FOR ALL THE HELP..... |
