Dan Clishe (Cody)
Registered Member Username: Cody
Post Number: 118 Registered: 1-2008 Posted From: 206.51.120.170
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 10:07 am: | |
The grandkids are coming in today from pennslyvania and they always keep me busy with the bus and camping so I was getting the bus all set up for the invasion of little feet. When I filled the water system and fired up the pump and plugged in the water heater,,,,,, no leaks! Not a flood or a trickle, not even a drop anywhere, thats never happened before and now I'm scared. |
Mark Morgan (Stormcloud)
Registered Member Username: Stormcloud
Post Number: 12 Registered: 9-2008 Posted From: 216.36.185.106
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 10:27 am: | |
Perhaps you inadvertently used dehydrated water. It's MUCH harder to see that stuff when there's a leak. Enjoy! Mark. |
Dan Clishe (Cody)
Post Number: 121 Registered: 1-2008 Posted From: 206.51.120.170
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 10:41 am: | |
I hadn't thought of that, you could be right. |
Post Number: 610 Registered: 7-2004 Posted From: 75.91.199.111
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 11:09 am: | |
It could be that the cracks in the copper plumbing just dried out and glued themselves together. Once the water gets a chance to soak in, you'll be able to see the leaks soooo much better! |
Post Number: 1445 Registered: 3-2007 Posted From: 76.4.118.153
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 2:26 pm: | |
check the water presure it might need adjusted to make sure it has enough to blow up the lines. Naw just kidding. sometimes things do go in our favour LOL Gomer |
Post Number: 2096 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, June 26, 2011 - 8:16 pm: | |
you sure water came out of the hose you filled it with? |
Dan Clishe (Cody)
Post Number: 123 Registered: 1-2008 Posted From: 206.51.120.170
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 4:34 am: | |
The water here is pretty good but now I'm thinking I should be bottleing it and selling it on the church networks, apparently it has some healing properties that I didn't know about cause there still arn't any leaks,, someone once said that water is a great beverage if taken in the right spirit lol. |
Post Number: 1446 Registered: 3-2007 Posted From: 76.4.118.153
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 9:30 am: | |
CODY!! Chessie it is your turn again LOL gomer |
Post Number: 612 Registered: 7-2004 Posted From: 75.91.199.111
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 9:37 am: | |
Halleluiah! It's a Mercal I tell ya, simply a Mercal! Next we'll have pictures of Iggles on a piece of toast selling on eBay! |
