Barry McCully (Turtle)
Registered Member Username: Turtle
Post Number: 40 Registered: 8-2007 Posted From: 71.7.161.192
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 5:10 am: | |
Have to replace one rad on my bus should I do one or both and where I don't run the bus in the winter should I re install the shutters or leave then out. Thanks |
Post Number: 1816 Registered: 12-2000 Posted From: 71.195.124.20
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 10:56 am: | |
Barry - Best to do both, no sense asking for problems from the other one down the road. Properly working shutters help bring the engine up to correct operating temperature year-round. Your choice. Make sure your seals around the radiators and the access doors are in good shape. You want all the air being pulled in by the squirrel cages to go thru the rads, not around them. FWIW & HTH. . .
Brice Abell (Babell2)
Registered Member Username: Babell2
Post Number: 25 Registered: 12-2010 Posted From: 74.190.239.81
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 12:07 pm: | |
I am destened for the same fate in the near future. My MC9 needs both radiators and shutters gone through. My thoughts are if you have to drain the system to replace one, do you want to drain the coolant and replace it again for the second? Brice |
Post Number: 26 Registered: 12-2010 Posted From: 74.190.239.81
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 12:10 pm: | |
sorry for double Brice (Message edited by babell2 on June 27, 2011) |
George M. Todd (George_todd)
Post Number: 1248 Registered: 8-2006 Posted From: 99.37.28.23
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 8:03 pm: | |
Shutters not only help the engine get up to temperature, they also help with fuel economy by reducing the blower horsepower requirement when cooling is not needed! |
Post Number: 1542 Registered: 7-2006 Posted From: 97.212.148.235
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, June 27, 2011 - 8:46 pm: | |
Yep...agree, RJ....and George. FWIW RCB (Message edited by chuckllb on June 27, 2011) |
