Gelecamion (Gelecamion) (66.1.43.112)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 22, 2004 - 11:27 am: | |
hI GUYS thank you for all the advice the bus yestarday I did some of your sugestions ant hte bus i ground /cealn all the batteries terminals , with a wire brush and a grinder the bus is a negative graound i did everything and i onlu could herar the click then i went to the back and i bridge the selenoide with a 1/2 wrench then the bus started for about 30 seconds or less it was a triupht for me then i had an oil leak i broke the nile the goes from the generator when i was istalling the starter so what is next after fixing the leak !!! reasoins why the switch does not start !!!? whire a new switch |
Doug (68.83.22.144)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 22, 2004 - 7:06 pm: | |
bad switch |
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, March 22, 2004 - 8:37 pm: | |
yes but where in the switch itself or wiring !!! Thank you !!! |
TWO DOGS (63.185.72.205)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, March 23, 2004 - 6:43 am: | |
sounds (?) like a bad solonoid... |
