Mold Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » March 2004 » Mold « Previous Next »
Tony (64.215.196.113)
Posted on Sunday, March 28, 2004 - 7:25 pm:
Have any of you guys ever been In contact with Mold In the removal of seats, If so what did you do to clean It up, If so what happened to you, what was the symptoms ( Medically ) what did you do to feel OK afterwards, I dont know for sure but I believe that I have been exposed to Mold
Thank you
Tony
66-Eagle-01 (69.22.121.11)
Posted on Sunday, March 28, 2004 - 7:49 pm:
We ran into the same problem with our Eagle. 50% water-bleach mix in pump-up garden sprayer killed the mold[use fan pointing out open window while spraying]We sprayed EVERYTHING, walls, ceiling, etc.The headaches went away after a few days.
FAST FRED (63.234.21.218)
Posted on Monday, March 29, 2004 - 5:15 am:
Sometimes folks have to lay up their coach in a science lab like Florida, where in the summer ,,,,,,,Anything Grows.
One technique to prevent mould is to run a dehumidifier , but that takes loads of electric .
The PANDA brand of Ozone generators drink little juice and there are even 12V units that could work off a solar setup.
Simplest of all is a quart of Formaldahide , capped with layers of aluminum foil.
Then a single pin hole is poked thru the cap.
On return the interior will be fresh , no Mold
BUT you MUST remove the formaldahide and air out the camper very well before occuping it.
Have used this trick on lots of boats and its effective and cheap.
Might work for you.
Tim Brandt (Timb) (12.8.192.60)
Posted on Monday, March 29, 2004 - 12:26 pm:
Having been a biologist for several years I would much rather deal with a little bleach water every now and then rather than formaldahide which is carcinogenic as well as mutogenic if you happen to be of child bearing years.
TWO DOGS (67.30.17.184)
Posted on Monday, March 29, 2004 - 4:59 pm:
wow...half baby...half bus.................. :)
TWO DOGS (67.30.57.236)
Posted on Monday, March 29, 2004 - 6:20 pm:
the baby didn't cry....it made that detriot diesel sound....whose got that sound bite ??
FAST FRED (63.234.23.22)
Posted on Tuesday, March 30, 2004 - 5:09 am:
The formaldahide is ONLY in the coach when its laid up and not in use for months on end.
A boat or coach left to rot with mildew will need a complete going over , not a clorox wash.
The mildew can stain paint and eat varnish off the interior , ITS ALIVE !! and wants to eat & populate the world.
Proper ventilation AFTER formaldahide is a great idea.
Tony (64.215.196.166)
Posted on Tuesday, March 30, 2004 - 6:16 am:
Hey two dogs
It made that Cummins sound, not that junker 2 stroke sound like you have
Posted on Tuesday, March 30, 2004 - 6:29 am:
But I did forget to say that I have one of them Junkers In my MCI-7,8V71, It smokes and makes lots of noise heats up on hills, but I do have to say that It has always got me there and back.
