Post Number: 2114 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 20, 2011 - 10:40 pm: | |
Do these electrical coils have the voltage that they are to operate marked on them? |
Post Number: 1198 Registered: 8-2006 Posted From: 74.33.48.167
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, July 20, 2011 - 11:19 pm: | |
They have the voltage marked on the disk where the shaft goes through the coil you may have to remove the keeper sometimes the disk get flipped over. I use 24V on a 12V system all the time they work good never used a 12V on a 24v couldn't tell you if that works or not bet it does good luck (Message edited by luvrbus on July 20, 2011) |
Dirk De Bakker (Kelvin12)
Registered Member Username: Kelvin12
Post Number: 30 Registered: 1-2010 Posted From: 124.168.55.188
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 21, 2011 - 5:52 pm: | |
G'Day, Are we talking about 6V92 jake coils here. This hadn't cross my mind before, now you have me worried. Still haven't started my motor yet so this was very timely. Thanks for this. Dirk |
Post Number: 2115 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 21, 2011 - 10:50 pm: | |
hey, thanks. Mine haven't worked since I bought the coach.Found a top came off one solenoid and oil passage clearance was 3 times as wide as should be on one unit. Need to check the top ones also. |
Post Number: 1199 Registered: 8-2006 Posted From: 74.33.48.167
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 21, 2011 - 11:31 pm: | |
John, you probably know this but the jumper tubes take a special o-ring seal cost you 3.05 ea at DD change those it will save you some grief down the line good luck |
Post Number: 2116 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 23, 2011 - 12:26 am: | |
Thanks...I'll check those. Looked like the gap backed off on one; looked like 1/4 inch gap. Also a top disc was lying down on head. I was planning on replacing that coil. That is why I thought I better check if it is 12 or 24 volt. Looks like they changed the coils. Mine need a spanner to remove. |
Bill Gerrie (Bill_gerrie)
Post Number: 527 Registered: 3-2006 Posted From: 216.198.139.38
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 23, 2011 - 9:34 am: | |
John When you replace the rubber seals turn the jumper screw till it lightly contacts the next casting then back off 1/3 of a turn to allow for working clearance. Hold the postion with a wrench and tighten the lock nut to prevent movement. Failure to allow working clearance will break off the jumper screw. Bill |
Post Number: 1200 Registered: 8-2006 Posted From: 74.33.48.167
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 23, 2011 - 10:26 am: | |
Like Bill says that is the reason for the special seals don't try and use off the shelf o-ring it will bite you |
