thomas flocks (Taflocks)
Post Number: 431 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 28, 2011 - 8:25 pm: | |
i have a shurflo water pump That will only work if i back the switch housing off a bit. any ideas? |
Sean Welsh (Sean)
Post Number: 1267 Registered: 1-2003 Posted From: 108.108.141.14
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 28, 2011 - 9:30 pm: | |
What model is the pump? The pressure switches on these pumps are actually very low-tech affairs, even the ones on the variable-speed models. Sounds like the switch diaphragm has a bit of foreign material trapped on it that is causing it to read full pressure all the time. When you back it out, that lets the spring-loaded diaphragm relax. I would remove the switch entirely and clean it off. Depending on model you may be able to remove and clean the diaphragm. Make sure there is no debris in or near the orifice. With a model number I may be able to give you more detail. -Sean http://OurOdyssey.BlogSpot.com |
Post Number: 1498 Registered: 3-2007 Posted From: 76.4.118.199
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 28, 2011 - 9:33 pm: | |
Tom Bad pressure switch. They are rebuid kits available at RV parts stores or maybe on line prices vary also.. Gomer[Sean] |
Post Number: 432 Registered: 9-2009 Posted From: 67.253.124.108
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 28, 2011 - 11:08 pm: | |
If we had a rv store near us....... I will get part number in the morning... |
