Cullen Newsom (Cullennewsom)
Post Number: 178 Registered: 2-2009 Posted From: 216.230.236.42
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2011 - 10:47 am: | |
Does anyone happen to know the range / specs for injector pop pressure for a 6v92ta? I'm building a pop-tester for my little W123 Mercedes, and I thought I might try to make one that would work for the bus as well. Thanks |
Ralph Peters (Ralph7)
Post Number: 200 Registered: 3-2004 Posted From: 75.206.235.238
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2011 - 10:45 pm: | |
If you build the tester, you need a spray guard! The units we used when I was in the AF, the guage went to 5,000lbs. Each engine mfgr. has different settings, also the +/- pop lb. are critical. What is the range pop pressure are the W123? Fuel at pop pressure will do serious damage to human tissue if you get to close or a line to the injector leaks. Our test units were hand operated and surplus units maybe available. Good luck, lots of older diesels had field rebuildable injectors, but todays???? |
Post Number: 179 Registered: 2-2009 Posted From: 216.230.236.42
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 29, 2011 - 11:30 pm: | |
Yeah, I agree one should be careful of high pressure liquids. I've got a nice piece of acrylic to make a guard with. IIRC The highest pressure in a stock OM617 turbo engine is ~130 bar. All the cool kids are building them these days out of a cheap-o bottle jack. Here's one of the threads detailing the construction. http://www.peachparts.com/shopforum/showthread.php?t=224334 Here's a shop that sells them for just under $200 http://www.mercedessource.com/node/5180 |
Tom Christman (Tchristman)
Post Number: 320 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Saturday, July 30, 2011 - 1:57 am: | |
Guess that's out of the question for the new truck engines running at 32,000psi! Good luck, TomC |
