Larry & Lynne Dixon (Larry_d)
Post Number: 336 Registered: 7-2005 Posted From: 50.39.221.113
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 15, 2011 - 12:04 pm: | |
Well after five of six years I find a new old spare tire, believe it or not. Question there is also a air line witha screw valve. Is this to be hooked to the tire and fill check the tire. I find what looks like an air chuck under the driver. Thanks Sam for helping. Larry |
Post Number: 1514 Registered: 3-2007 Posted From: 76.4.118.199
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, August 15, 2011 - 12:24 pm: | |
Larry Why not!! this is a valueable thing to have on any coach. All you can do is check it and see if it works and you have it for air tool and whatever you use air for LOL GOOD FIND~ Gomer |
Dave Walker (Chrome_dome)
Post Number: 373 Registered: 3-2010 Posted From: 74.41.14.235
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 10:45 am: | |
By screw valve ; Do you mean a schrader valve like is the fill valve type on a tire. It maybe the system emergency fill valve for the brake system. Check to see if it goes to an auxiliary tank or where it is hooked up to. Chromie (Message edited by chrome_dome on August 17, 2011) |
Post Number: 337 Registered: 7-2005 Posted From: 50.39.221.113
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 2:14 pm: | |
The valve under the seat is like a tire valve and the one on the hose is like would screw to the tire valve. That hose does have a hole in it. |
