Jim Sanders (Sandy)
Registered Member Username: Sandy
Post Number: 93 Registered: 1-2011 Posted From: 69.199.96.250
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 11:32 am: | |
Hey guys A Cat 3208 What oil does it use? How much??? What weight. THANKS a bunch fellows JIM |
Jim Sanders (Sandy)
Post Number: 94 Registered: 1-2011 Posted From: 69.199.96.250
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 11:57 am: | |
Hey guys a post scrip to the post WHY IN He-- should i buy a manual just ask a BUS NUT Ha JIM |
Post Number: 675 Registered: 7-2004 Posted From: 98.20.56.115
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 12:09 pm: | |
15W40 will work fine Jim, but I would use as cheap an oil as I could, you don't want to spend too much money on a boat anchor. |
Jim Sanders (Sandy)
Post Number: 95 Registered: 1-2011 Posted From: 69.199.96.250
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 12:47 pm: | |
Now who is beeing a smart a-- Now!!!!!! SAD BUT TRUE Jim |
Post Number: 2128 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 6:01 pm: | |
http://www.wanderlodgeownersgroup.com/downloads/3208%20Cat%20Engine%20Questions%20and%20An swers.pdf |
Post Number: 1235 Registered: 8-2006 Posted From: 184.10.191.147
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 6:15 pm: | |
If the 3208 hasn't been upgrade to the 3 ring piston nothing stays in it long enough to worry about it, the dumbest thing Cat ever did trying to use 1 ring per piston |
Post Number: 1572 Registered: 10-2006 Posted From: 76.195.74.163
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 6:26 am: | |
I have a CAT 1160 , the non throw away version of the 3208, hooked to a 6 speed Allison , factory new 150,000 miles ago. $1500,located Arcadia FL. Pushed a Flex VL 100 at 10mpg , and the higher RPM engine allowed 85 mph should that be a plus. 70mph is no longer the limit in many advanced states. FF |
Tom Christman (Tchristman)
Post Number: 326 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 11:51 am: | |
The main problem with either the 1160 or 3208 was it is a linerless engine that the block was not hardened. Hence around 200,000 miles, the cylinder would mushroom out and cause the rings to bounce and eventually fail. The cure was to bore the block then install steel dry cylinder liners with the fore mentioned 3 ring pistons. Then you had an engine that could go 4-500,000 miles. If you have a turbocharged 3208, istalling an air to air intercooler would allow up to 320hp from it. Good Luck, TomC |
Post Number: 1575 Registered: 10-2006 Posted From: 76.195.75.120
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 18, 2011 - 7:02 am: | |
Haven't looked at Da Book in a while , but I believe the 1160 HAS replaceable liners. FF |
