Brandon M (Brandon314159)
Registered Member Username: Brandon314159
Post Number: 36 Registered: 3-2011 Posted From: 174.255.172.249
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 12:05 pm: | |
Hey busnuts! Just a quick shoutout...looking for a spacer ring for either a VS2-8 or a V730. Anyone have a spare/one their willing to part with? Could also be interested in a 5.25" bellhousing spacer for the detriot 6/8 cylinder variant. Contact me here or off list. Thank you, Brandon |
Post Number: 2127 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, August 16, 2011 - 5:57 pm: | |
the Flxible 30 footer that I dismantled had a 6v-71 and a V730 with NO spacer |
Paso One (Paso_1)
Registered Member Username: Paso_1
Post Number: 193 Registered: 11-2004 Posted From: 142.165.246.240
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 10:37 am: | |
My spare 6V71 with the V730 does not have a spacer
Post Number: 40 Registered: 3-2011 Posted From: 173.8.221.225
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 1:32 pm: | |
Bummer!...anyone got a 2 5/8" bellhousing spacer I could buy? Thanks :-) |
Post Number: 679 Registered: 7-2004 Posted From: 98.20.56.115
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 2:37 pm: | |
Brandon, did you see my post on your original thread? |
Post Number: 41 Registered: 3-2011 Posted From: 173.8.221.225
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 6:45 pm: | |
Hey Dal, I went and re-read your comment. The issue is purely a 'depth of bellhousing' issue. I have photos to demonstrate on the camera. The bellhousing on my 6-71 is much shallower than a 6v71/8v71, thus I need a thicker spacer to make up for the difference. I was advised that 6-71's could come with deeper bellhousings, so that may have been the bolt-up that you saw. I'd still like to find another spacer OR eventually build/find a single 5.25" spacer. Thanks for following up! |
Post Number: 2130 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, August 17, 2011 - 7:04 pm: | |
might be easier and cheaper to change the housing on the end of the engine. |
Mel La Plante (Mel_4104)
Post Number: 177 Registered: 7-2006 Posted From: 173.180.119.253
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 18, 2011 - 10:12 am: | |
Brandon call me at 1 250 248 2766 i have one but need to be sure it is what you want. after 6 pm is a good time i do not answer e mail. tks. mel 4104 |
Post Number: 2131 Registered: 10-2003 Posted From: 71.58.71.157
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, August 18, 2011 - 9:18 pm: | |
OK, I saved the engine housing that the V-730 bolted up to. surface to surface(machined)-6 5/8 inches. Depth of housing recess where trans bolts to is 4 3/8. This housing of from the Flxible with 6V-71. |
Post Number: 42 Registered: 3-2011 Posted From: 173.8.221.225
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, September 27, 2011 - 5:32 pm: | |
Hey Mel, Your email address' don't seem to work? I will try giving you a buzz tomorrow. Need to see if you have a v730 spacer or a VS2-8 :-) Thanks! -Brandon |
