Self tappers or rivets Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » May 2004 » Self tappers or rivets « Previous Next »
captain ron (207.30.240.162)
Posted on Wednesday, May 12, 2004 - 2:56 pm:
I'm ready to put the new .032 aluminum over my existing skins on my 4905. any reason not to use white self tappers rather than rivets?
TWO DOGS (65.177.144.18)
Posted on Wednesday, May 12, 2004 - 4:25 pm:
POP RIVITS !!!
joe shelton (64.222.152.102)
Posted on Wednesday, May 12, 2004 - 4:57 pm:
i'm not sure what 'white self tappers" are. White painted self tapping sheet mtl screws i would guess. rivets are really the best way to go imho. the screws will rust over time and will react with the alum skin.
Joe
4106
William N DeGroot (Billdegroot) (171.72.5.240)
Posted on Wednesday, May 12, 2004 - 5:40 pm:
I would not use pop rivets-they will leak. I used aluminum shave-head rivets that have a small rubber washer to seal the hole.
TWO DOGS (158.254.225.173)
Posted on Wednesday, May 12, 2004 - 5:54 pm:
pop rivits won't leak
TWO DOGS (63.185.64.25)
Posted on Wednesday, May 12, 2004 - 7:03 pm:
capt. ron....what have you done to the irregular surface 'under' this .032 alum. sounds like this is going to have more puckers than an old maids kiss...
captain ron (207.30.240.13)
Posted on Wednesday, May 12, 2004 - 9:05 pm:
I screwed an 1/8" thick by 1" aluminum bar the length of the area I am covering 4' down from the edge of the roof line. I then attached 1/8" foam between that area cuting it 4" short of the roof line so I can taper the aluminum into that area and but it into the roof sheeting. .032 is only .008 thinner than .042 which is not much more than a human hair and cost $10 a sheet less.
I tried a sample piece and it looks great. very smooth.
TWO DOGS (63.185.64.34)
Posted on Wednesday, May 12, 2004 - 9:16 pm:
sounds good....GO CAPT. RON
captain ron (207.30.240.101)
Posted on Wednesday, May 12, 2004 - 9:22 pm:
another question is how to seal the aluminum at the top and how far apart to rivet or screw along the top. I bought a case of latex caulk with silicone in it. it is a paintable caulk.
TWO DOGS (158.254.225.241)
Posted on Wednesday, May 12, 2004 - 10:10 pm:
would use pl constructin adheasive at home depo........and 4"....and YOU WILL be sorry tf you use screws
