Moe Hollow (Moehollow)
Registered Member Username: Moehollow
Post Number: 104 Registered: 12-2007 Posted From: 71.102.18.102
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 07, 2011 - 3:56 pm: | |
Time to change oil in my allison 644. It used to be that we looked for a C-4/ dex2 or 3. Now Allison wants everyone to buy Transynd, which is rather expensive. I have read where the military uses a 15w40, C-4 oil like Rotella T3. I have also heard of using 30w drive train oil, or hydraulic/transmission oil. I was wondering what others here are using. Thanks |
Laryn Christley (Barn_owl)
Post Number: 720 Registered: 10-2006 Posted From: 108.15.206.248
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, September 07, 2011 - 10:10 pm: | |
My v730 gets Dex3. |
Jim and Myrna Lawrence (Daffycanuck)
Registered Member Username: Daffycanuck
Post Number: 78 Registered: 10-2004 Posted From: 142.165.85.203
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 12:12 am: | |
My 650 gets DexIII |
Ed Hackenbruch (Ed_hackenbruch)
Registered Member Username: Ed_hackenbruch
Post Number: 16 Registered: 12-2006 Posted From: 166.250.0.233
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 12:40 am: | |
i had them change my 644 over to Transynd. |
Post Number: 1264 Registered: 8-2006 Posted From: 184.10.191.147
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 12:48 am: | |
I always used CAT TDTO 10w oil in the 740 good enough for a $35,000 Cat transmission was ok for me never had a problem with one using it over the years. Cat also sells a synthetic blend that is good oil. The Transynd is a must for the World Transmissions but I wouldn't spend that type money for oil in a 644 it takes 2 changes good luck |
Dave Walker (Chrome_dome)
Post Number: 386 Registered: 3-2010 Posted From: 74.41.14.235
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 1:15 am: | |
My mt 654 uses good old regular ATF Red Dave |
Post Number: 105 Registered: 12-2007 Posted From: 71.102.18.102
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 2:48 am: | |
Thanks- It seems some are happy with regular Dex III. I do like the idea of the TDTO except I just looked up the temp range for the 10 and 30 wts, and they are rather low. The multigrade (TDTO-TMS)is rated to about 110 degrees though. Any reason that wouldn't work? |
Post Number: 1266 Registered: 8-2006 Posted From: 184.10.191.147
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 9:33 am: | |
Moe are you sure that is not a 110C not degrees good luck |
Post Number: 106 Registered: 12-2007 Posted From: 71.102.18.102
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 11:14 am: | |
Yeah, Although the chart was in C, I did a rough switch to F. Unless I am missing something, it looks like the F numbers are -4 to 50 for 10w, 32 to 95 for 30w, and -4 to 109.4 for TMS. Here's the link I got http://docs.google.com/viewer?a=v&q=cache:9jrsP0K1C9UJ:www.cat.com/cda/files/1386248/7/PEH P8035-02.pdf+caterpillar+tdto+oil+temperature+range&hl=en&gl=us&pid=bl&srcid=ADGEESjyNjLmV hNU5-GsBAN2VQTal-Bmt0bFhvVe7q1EKSgcvwXXAMlyw1Itr-29x4S67e0SufOSsqTrWs2_xK7ykAtf94Gq_yBfFvz jCLNVxGkOOC4Nu6XvwJ2Pv2UJvvGltDCvuzdJ&sig=AHIEtbSt8NTn77mwP8pgqev0hcKkFqV6Pg |
Post Number: 673 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 11:53 am: | |
Moe, I can't access your link, but those temp ranges look like they are meant for ambient air temps, not oil temps. |
Post Number: 107 Registered: 12-2007 Posted From: 71.102.18.102
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 08, 2011 - 11:56 am: | |
Sorry if I was not clear. They are ambient air temps as you say, but isn't that critical too? |
Post Number: 745 Registered: 5-2007 Posted From: 74.2.251.162
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 09, 2011 - 5:19 am: | |
I'm getting ready to install a 740 in our Eagle. What is the current recommendation? |
Post Number: 17 Registered: 12-2006 Posted From: 166.250.1.131
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 09, 2011 - 8:49 am: | |
The Detroit shop did a complete flush and filter change on mine so i did not have to do a second change. The initial cost to change over is more but the savings comes from the increased service interval. Cheaper in the long run. |
Post Number: 1267 Registered: 8-2006 Posted From: 184.10.191.147
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 09, 2011 - 8:59 am: | |
Paul, the 740 shifts the best with 15/40 C-4,I have always used Cat Fluid it is the same as Delo 100- 10W those transmissions run a million miles on DEX or other fluids all the hype about Transynd I never bought into for 740 after all they get about 300,000 from the world transmission using Transynd wonder what they would not using it lol.7 or 8 gals at 10 bucks a qt naw not this one |
