Perkins Fuel Pump Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » May 2004 » Perkins Fuel Pump « Previous Next »
HondoJoe04 (66.74.52.69)
Posted on Monday, May 24, 2004 - 12:21 am:
Hi,
My 12kw Kohler gen is powered by the 4 cyl Perkins diesel.
The fuel pump just started to leak & I want to run it this holiday wknd. Going to Napa for help tomorrow. But Does anyone have any options... if this crossses over to something or know of a place I can call to order one for overnite delivery?? Thanks, Joe
TWO DOGS (65.179.192.155)
Posted on Monday, May 24, 2004 - 12:28 am:
try THERMO KING.....or someplace that does maintanance on refers
mel4104 (208.181.100.15)
Posted on Monday, May 24, 2004 - 10:36 am:
if you are near a farm eq. dealer or are near a coast line then try them as a lot of fish boats have them also stationary eg. use them, and a lot of truck shops have parts for them.
choochoo (206.176.198.238)
Posted on Monday, May 24, 2004 - 11:44 am:
hondo
.You may want to try a Cat dealer they now own Perkins or a Massey Fergusen farm dealer they use a lot of Perkins.
Ted
Stephen Fessenden (Sffess) (65.154.177.138)
Posted on Monday, May 24, 2004 - 10:20 pm:
These people may be able to help you. They are a Perkins dealer and they rebuilt the injection pump on my Perkins powered Kohler 12KW generator. They also have a Tallahassee, FL Shop.
Shiver Diesel
1702 Carpenter Rd.
Tifton, GA 31794
Tel: 912-382-1595
Fax: 912-382-1573
Posted on Tuesday, May 25, 2004 - 1:05 am:
Thanx for the tips!!
Got it going okay. Found the fuel line to be loose on the output side! Easy fix, mostly because the unit is on a slide out & I could then easily get at the fuel pump. Checking the lines found they were all a bit loose!! so with a bit of TLC all is well! Thanx again! Joe
