Brake Failure! Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » May 2004 » Brake Failure! « Previous Next »
joe shelton (64.223.164.84)
Posted on Tuesday, May 25, 2004 - 8:57 am:
I normally put my chalks behind the wheels but yesterday in a hurry didn't after parking our 4106 in front of the house on a 5% grade (will always use in the future). 3 hours later found the tail end of the bus half way out in the street and the front turned wheels had climbed the fence and bank enough to stop her (thank God). Had to climb in thru a window and start'r up. The park break was still on but I can't figure what would cause this. My compressor is passing oil and is to be replaced in 2 weeks along with total break/air system check. Is it safe to drive on a short trip before servicing? Have MiniMax break cans. Thanks, Joe
Bill Gerrie (209.50.74.86)
Posted on Tuesday, May 25, 2004 - 9:15 am:
Joe
About the only way I can see is the rear brakes are so far out of adjustment that the shoes are not pressing on the drum hard enough. You can always back up easier then forward with the brakes on. It could be the system is full of oil but the parking system should have worked. I personally wouldn't drive the coach till I found out for sure what the problem is. Your system could be so full of oil that the brakes just won't come on when you need them. Bill
TWO DOGS (65.177.144.58)
Posted on Tuesday, May 25, 2004 - 9:57 am:
that is strange !!...usually no air...means you aren't going anywhere...guess I will have to agree...shoes must not be touching, YOU DEFINITELY need to learn how to adjust your slack adjusters..
Posted on Tuesday, May 25, 2004 - 10:52 am:
...and now you see why ALL truckers who carry dangerous stuff use wheel chocks as routine! Isn't it funny that the first time you decide "it's ok" is usually when the universe will decide to hand you a lesson! Thankfully an easy one. Mine was in '66 when I was in a hurry to get ready for a date. I pulled my '57 chevy in and parked it on the wrong side of the street (about a 3% grade), in a hurry I set the parking brake and ran into the house to get a quick shower. Didn't turn the wheels into the curb and didn't park in my driveway as I usually do...
...came out to find what was left of my car sitting 6 feet inside my "down-the-hill" neighbor's living room. Ugh. What a mess. And, no date that night!
The only time anything like that ever happened, probably because I was in a hurry :)
Gary
James Maxwell (Jmaxwell) (66.81.34.2)
Posted on Tuesday, May 25, 2004 - 11:19 am:
Mini-Maxi's have a long history of this and that explains why they quit making them. Not necessarily anything to do with oil in the system or out of adjustment shoes. The design of the pod allowed them to release; all it takes is a small loss of pressure from the activating pressure.
John Rigby (65.112.227.94)
Posted on Tuesday, May 25, 2004 - 11:50 am:
Are you sure we are not confusing this brake control with the old ICC control that we all had and disconnected, because when the air leaks down on the ICC the breaks reiease??
John
joe shelton (68.237.135.135)
Posted on Tuesday, May 25, 2004 - 12:13 pm:
i thought that when i had a loss of air pressure (to 60 psi or less) then they would lock-up. in fact i'm sure of it. and when i apply the park break, aren't i removing air pressure to the cans which allows the break springs to engage the breaks? thanks to all. joe
Posted on Tuesday, May 25, 2004 - 12:50 pm:
I only know about the original ICC break that my 4104 came with the breaks are on and set as long as you have air. No air they are off.
I disconected the ICC control because you can set it one night and in the morning wake up and the bus has rolled off down the road.
Spring breaks, which I added, ONLY realse when air is applied at 60 psi or more. Below this they are ON. No air you cannot move, unless you get underneath and back the screw/bolt off to back the spring off.
Joe I would think you may have the old ICC system,
John
Posted on Tuesday, May 25, 2004 - 2:21 pm:
i don't have the old ICC system; when i loose air pressure 60 psi or less the breaks come ON. but i think i may have an idea as to what my prob is. i think one of the springs is broken. i believe i can drive it safely but can not rely on the parking break. what do you think?
TWO DOGS (65.177.144.205)
Posted on Tuesday, May 25, 2004 - 5:15 pm:
please guys......it's brakes
John Rigby (24.174.238.253)
Posted on Tuesday, May 25, 2004 - 9:16 pm:
Then Two Dogs, explain 1) maxie brakes 2)ICC brakes 3)spring brakes.and all the rest.
dont give us a spelling lesson.
Give us a lesson on breaks or brakes.
John
Derek (24.85.245.203)
Posted on Tuesday, May 25, 2004 - 9:33 pm:
I don't see any reason to rip on TWO DOGS there... He's got it right, brakes..
All very important components.. What if you're driving along and lose all air pressure because of a line rupture or something? How are you going to stop on that seemingly small 6% grade, when your parking brake cannot hold the coach on a driveway?
Get it working first, I'd say. I'm sure Buswarrior could add to what I've said.
TWO DOGS (65.179.208.112)
o.k. back in the 70's....I worked for a company that manufactured grain trailers....I was the painter....(but) one day the boss called a meeting...& told everybody that they had a month to get rid of this one brakeing system& we needed to get rid of the ones in the warehouse that had the brakes that you guys are talking about....BECAUSE they were no longer going to be able to sell them...because Gov. said they were inferior....guess what...bet that system is what is on that particular bus...sorry about the spelling lesson...it was like fingernails on a chalkboard
Phil Dumpster (24.16.243.37)
Posted on Wednesday, May 26, 2004 - 2:22 am:
Spring brakes are often called maxi brakes. Big spring held in compressed state by air pressure greater than 30PSI. (Not 60 PSI, below 60 PSI is when your alarm buzzer is supposed to sound.)
Springs are the best, in my not so humble opinion. They are not perfect (don't throw away your wheel chocks, you'll still need them) but when working right, when they are on they are ON.
Some older brake systems relied on air pressure for the parking brake. No air pressure, no parking brake and the coach rolls away.
Some trucks and coaches have a cable or linkage operated driveline brake on the tail of the transmission for the parking brake. On an incline, park one wheel on dry concrete or asphalt, and the other on a slippery surface and your bus will do the moonwalk down the hill when viewed from the slippery side.
Why do people call them breaks when they are brakes? I think this is what Two Dogs was trying to point out. If you think he was being petty, then take some time out to learn to spell properly. It makes you look like an idiot otherwise.
James Maxwell (Jmaxwell) (66.81.208.117)
Posted on Wednesday, May 26, 2004 - 2:27 am:
TD is right on here. He is referring to the Mini-Maxi setups; and they were taken off the market as unsafe as they would release with a small air loss from application pressure. They were quite different than DD3's (Maxi's) in design and operation, and both Mini-Maxi and Maxi's are different than Spring brakes in design and method of operation.
RJ Long (67.181.232.189)
Posted on Wednesday, May 26, 2004 - 4:11 am:
This should probalby be in it's own thread, but we'll have some fun with it for a few minutes anyway. . .
"Why do people call them breaks when they are brakes? I think this is what Two Dogs was trying to point out."
Ah, the joys of the English language!! It's not only spelling that trips us up, it's also syntax - the correct spelling, but misapplication. For example:
He took a break while working on his brakes. . .
They're going over there to pick up their bus. . .
I'm going to pick-up two six-packs, too!
The whole building collapsed into that hole. . .
Anybody else have some?
Playfully,
RJ
PD4106-2784
Fresno CA
PS: Syntax is not what they charge you for visiting a brothel in NV!! LOL. . .
pete (152.163.252.199)
Posted on Wednesday, May 26, 2004 - 6:57 am:
joe,
im thinking bill is right about the breaks being out of adjustment..mine did the same thing..but didnt go for a cruze by itself..just wonk lock up correctly. it is going in today for PA inspection...ill let you know what is found
Pete
Posted on Wednesday, May 26, 2004 - 7:41 am:
You want to get correct english Phil,then go to a english languish board.This boards for bus nuts.All this talk about spelling, this is why people who could post don,t. Be on your way.
I have spell check on my computor but it dont work on here.
John
TWO DOGS (63.185.73.142)
Posted on Wednesday, May 26, 2004 - 9:18 am:
whats that in the road ahead
whats that in the road a head
naaa I misspell things too...was just hard for me to concetrait on brakes,when everybody was talking about takeing a break...my a.d.d. kicking in..
Jim Ashworth (Jimnh) (172.158.193.157)
Posted on Wednesday, May 26, 2004 - 9:40 am:
Seems like we're all languishing in misspellings.
One clarification, DD3's aren't Maxi's. Maxi's have springs to apply the parking brake without air. DD3's use air to apply the parking brake and an internal lock keeps them on.
Jim
Larry (208.18.102.147)
Posted on Wednesday, May 26, 2004 - 9:58 am:
Artery......The study of paintings.
Benign.....................What you be after you be eight.
Bacteria....................Back door to cafeteria.
Barium......................What doctors do when patients die.
Cesarean Section............A neighborhood in Rome.
Cat Scan........Searching for Kitty.
Cauterize..................Made eye contact with her.
Coma........................A punctuation mark.
Dilate......................To live long.
Enema.....................Not a friend.
Fester......................Quicker than someone else.
Fibula......................A small lie.
Hangnail....................What you hang your coat on.
Impotent....................Distinguished, well known.
Labor Pain........Getting hurt at work.
Medical Staff...............A Doctor's cane.
Morbid......................A higher offer than I bid.
Nitrates....Cheaper than day rates.
Node.......................I knew it.
Pelvis......................Second cousin to Elvis.
Post Operative..............A letter carrier.
Rectum.....................Darn near killed him.
Seizure.....................Roman emperor.
Tablet....A small table.
Tumor......................More than one.
Urine.......................Opposite of you're out
Varicose.........Near by
mel 4104 (208.181.100.86)
Posted on Wednesday, May 26, 2004 - 10:33 am:
well people it sure would be nice to spell evey thing right and the proper way how everwe are not all the same and some of us mess up but that is ok with me so enjoy what the other person is trying to say and learn from it, just be gratefull you are not near where the air turns blue around me when every thing goes wrong as that is when i really mess up the lingo. ps, and everyone keep on posting regardless what ever is said just go for it........
TWO DOGS (65.179.209.116)
Posted on Wednesday, May 26, 2004 - 10:40 am:
and that terrible book:
Men are from Mars
Women are from uranus
CoryDane RTSII (66.155.188.243)
Posted on Wednesday, May 26, 2004 - 11:42 am:
BRAHAHAhahaHAhahahahaaaa
Oh, Two Dogs
You inserted that at just the perfect point!
LOL,
Where do these things come from? LOLlol LOL
"Imagine Your Dreams"
cd
TWO DOGS (63.185.97.40)
Posted on Wednesday, May 26, 2004 - 12:20 pm:
yeah....recomended reading if you want to learn to play stupid games with women,and want to destroy your stupid relationship in 24 hours..
Don't get me wrong...I LOVE WOMEN...it's just that their head is wired-up different :
step on the brake...no brake,but radio comes on
left turn signal,....naaa....radio comes on
joe shelton (64.222.180.140)
Posted on Wednesday, May 26, 2004 - 4:21 pm:
I’m the one who started this and when one of us posted “learn to spell properly” and “you look like an idiot” I needed to take a break. I’m glad I did. But I guess I’m less of an idiot now that I know how to spell it but I still smell as sweet (Shakespeare) and I still can’t spell. If my spelling causes heartburn then please pass over my posts. Anyhow, the brakes on my bus are Mini-Max made by International Transquip out of Houston TX. If I remember correctly, George Lowry told me that they had a good product but went out of biz cause of poor management. My original question was “My compressor is passing oil and is to be replaced in 2 weeks along with total break(brake)/air system check. Is it safe to drive on a short trip before servicing?” I think it’s safe to drive but thought I’d check and see what you all thought. YHS, joe
Posted on Wednesday, May 26, 2004 - 4:22 pm:
Two Dogs,
Hahahahahahahahahahah!!! I agree with Cory Dane, keep 'em coming...
TWO DOGS (63.185.96.221)
Posted on Wednesday, May 26, 2004 - 4:42 pm:
lighten up joe....ya' need more fiber....
Paul Tillmann (Paultillmann) (24.105.194.23)
Posted on Wednesday, May 26, 2004 - 6:51 pm:
Gee, I thought spring brake was a big party in Daytona Beach?!?! Oh well, I learn something new everyday!
R Johnstone (Chilebrew) (67.203.199.21)
Posted on Wednesday, May 26, 2004 - 6:52 pm:
TWO BEE RED ALLOWED
SPELL CZECH
Eye halve a spelling chequer. It came with my pea sea.
It plane lea marques four my revue miss steaks eye kin knot sea.
Eye strike a quay and type a word and weight four it two say
Weather eye am wrong oar write. It shows me strait a weigh.
As soon as a mist ache is maid, it nose bee fore two long
And eye can put the error write; it’s rarely ever wrong.
Eye halve run this poem threw it, I am shore your pleased two no,
It’s let her perfect in it’s weigh. My chequer tolled me sew.
Posted on Wednesday, May 26, 2004 - 6:54 pm:
Spell Czech cribbed from another board---not my original.
Nelson (64.12.116.135)
Posted on Wednesday, May 26, 2004 - 7:09 pm:
The Mark-Twainian Principle of Spelling
Anybody who can't figure out more than one way to spell a word, lacks imagination!
Mark Twain
Posted on Wednesday, May 26, 2004 - 7:12 pm:
tanks four oll you're elp. i'll ast some one els
Posted on Wednesday, May 26, 2004 - 7:35 pm:
Joe -
Humorous malaprops with the English language aside, back to your original question: Is it safe to drive on a short trip before servicing?
I'll answer that with a "that depends". Have you done a pre-trip inspection brake check on the system recently? By doing one, it will help you determine the answer to your question.
If it passes the brake check, then enjoy your trip.
If it doesn't pass the brake check, then you need to get the system serviced, which I understand you already have scheduled.
There is a pre-trip inspection located in the Articles of Interest section of BNO, off the main index page, and it includes a complete brake check. After reading thru it, if you have any questions, drop me a note privately (r4106 at comcast dot net) and I'll help walk you thru it.
HTH,
RJ
PD4106-2784
Fresno CA
Posted on Thursday, May 27, 2004 - 8:40 am:
gee, all that to get what I needed. Thanks RJ. I'm a bit sencitive on the spelling thing cense I never kud spel. thanks, I'll go see if I can find my way to the referenced file. joe
FAST FRED (4.245.212.104)
Posted on Thursday, May 27, 2004 - 3:35 pm:
The old ICC brakes were fore EMERGENCY STOPS, not poo boy parking brakes.
What happened to the good old Johnson Bar that most GM came with?
They will hold on a 15% grade , air or not , and don't "pop off".
AS well as holding back in a really steep hill, to keep from rolling backward as the clutch is eased in.
Johnson Bar = no suprises ,
Works for me,
Posted on Thursday, May 27, 2004 - 6:05 pm:
Joe. Im glad you got the info you need,sorry about the abuse. this is what bus nuts on the other boards put up with all the time. Now it seems like its slowly creeping over to the best board on the net.It would be nice if they would just,go on back to the other boards.
John
H3Jim (68.107.62.94)
Posted on Thursday, May 27, 2004 - 6:43 pm:
Not exactly on the post, but pretty funny...
D A M N I T O L
Take 2 and the rest of the world can go to hell for up to 8 full hours.
ST. M O M M A'S W O R T
Plant extract that treats mom's depression by rendering preschoolers
unconscious for up to two days
E M P T Y N E S T R O G E N
Suppository that eliminates melancholy and loneliness by reminding you of
how awful they were as teenagers and how you couldn't wait till they moved
out.
P E P T O B I M B O
Liquid silicone drink for single women. Two full cups swallowed before an
evening out increases breast size, decreases intelligence, and prevents
conception.
D U M B E R O L
When taken with Peptobimbo, can cause dangerously low IQ, resulting in
enjoyment of country music and pickup trucks.
F L I P I T O R
Increases life expectancy of commuters by controlling road rage and the urge
to flip off other drivers.
M E N I C I L L I N
Potent anti-boy-otic for older women. Increases resistance to such lethal
lines as, "You make me want to be a better person. Can we get naked now?"
B U Y A G R A
Injectable stimulant taken prior to shopping. Increases potency, duration,
and credit limit of spending spree.
J A C K A S S P I R I N
Relieves headache caused by a man who can't remember your birthday,
anniversary or phone number.
A N T I-T A L K S I D E N T
A spray carried in a purse or wallet to be used on anyone too eager to share
their life stories with total strangers in elevators.
N A G A M E T
When administered to a husband, provides the same irritation level as
nagging him all weekend, saving the wife the time and trouble of doing it
herself.
TWO DOGS (158.254.224.202)
Posted on Thursday, May 27, 2004 - 7:50 pm:
oh......and.....
...................MR2DUCKSOAIR..................
TWO DOGS (63.185.80.211)
Posted on Thursday, May 27, 2004 - 10:33 pm:
rude.....the guy got answers....3 or 4 guys told him he had inferior brakes....but he couldn't understand that...I would have suggested him trying to find somebody to put spring brakes on it....BUT.....he was just waiting for somebody to tell him to drive the bus...after that....he was happy
Peter Broadribb (Madbrit) (67.136.117.38)
Posted on Friday, May 28, 2004 - 2:56 am:
One problem I see is that people wander into these groups, want answers from total strangers, in fact, sometimes demand answers and then complain when they don't get the answer they wanted. They don't seem to appreciate that all of the people who give out the info and advice don't get paid and do it as a favor and definately not for abuse.
Some questions are so basic that a search on Google will produce the answer, so they are either too lazy or won't try to learn about the internet. Nearly all of us are self taught in that field. What's so hard than to type a few words into a search engine?
Many lurkers, fewer contributors. We are loosing more and more of the experts due to the abuse that these kind people are being subjected to, when all they try to do is help. Sure there is a little funnin' and some ribbin' too, but that is often between the regulars.
Peter.
TWO DOGS (63.185.81.124)
Posted on Friday, May 28, 2004 - 6:46 am:
appreciate your support Peter..
Posted on Friday, May 28, 2004 - 7:50 am:
I also appreciate your support Peter.
ChuckMC9 (Chucks) (68.240.232.51)
Posted on Friday, May 28, 2004 - 12:34 pm:
Posted on Friday, May 28, 2004 - 12:35 pm:
and I appreciate EVERYONE'S support. I'll echo Peter's comments and add again that there's no way I could have attempted this huge project without BNO and friends. My sincere thanks, and if I've been contributing too much to the funnin' and noise level, just don't put sand in my tank!
Stephen Fessenden (Sffess) (65.129.241.239)
Posted on Sunday, May 30, 2004 - 5:37 am:
If the brakes are not spring brakes then they have a mechanism to hold the brakes on once the parking brakes are applied using reserve air pressure. It takes airpressure to overcome this mechainical lock and release the brakes. If the brakes release when the air pressure drops, this mechanical lock is not working and the brake cannisters need rebuilding with attention to cleaning and repairing this mecnainism. It is not safe to drive, because there is no air to reapply the brakes until the engine runs a few minutes. Imagine jumping in that bus as it started to roll backwards and finding no brakes at all. Chocks are a great idea but the cans need repair.
