Captain Ron (207.30.240.128)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 28, 2004 - 2:33 am: | |
If I leave my batteries hooked up even for a few hours they go dead. and my lights are very dim until I rev the motor even when my batteries are fully charged. my amp gauge seems not to be working.I have a 1970 4905 8v71 |
CoryDane RTSII (66.155.188.83)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, May 28, 2004 - 5:02 am: | |
Capt Ron I will try to give you basic battery info If the battery is at end of life, even if they are disconnected from the cable, they will go dead. You say if left HOOKED UP they are dead in a few hours... you seem to have a big drain on the battery if they are in good condition. The amp guage seems not to be working, you may have a short before the amp guage shunt. If you have am amp clamp on meter, it might be able to help you find the problem. your head lights are dim, they should be connected AFTER the Amp guage shunt so a short will do this. If you know where the shunt is, try disconnecting it and see if the battery has load (current) on the positive cable. If not, the problem is beyond the shunt. It sounds, at this point, it may be before or AT the shunt for the Ampmeter. Sorry I can't be more informative for you, I hope it is a small problem. "Imagine" cd |
Stephen Fessenden (Sffess) (65.129.241.239)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, May 30, 2004 - 5:01 am: | |
Do you have a bad alternator? Sounds like you are barely charging and an alternator can short and drain the battery. Try disconnecting only the alternator and see if the batteries hold a charge. I just recently had that very problem in a car. New alternator fixed it. |
