Post Number: 1284 Registered: 8-2006 Posted From: 173.87.190.101
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 06, 2011 - 10:05 pm: | |
? for the GM guys any short cuts or unforeseen problems I can run into removing the engine with a automatic. I don't have a manual and the owners don't either plus I don't want to buy one, I know the piping will need to be redone as I am removing a 8v71 TA and replacing it with a 8v71 NA anything else you guys can think of I would appreciate your help as I don't do much GM work hardly any till lately Thanks in advance |
Derrick Thomas (Thomasinnv)
Registered Member Username: Thomasinnv
Post Number: 28 Registered: 10-2010 Posted From: 173.118.89.228
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 2:08 am: | |
Probably easiest to just remove the entire cradle and separate the engine and tranny on the shop floor. 2 bolts on the front bulkhead, and 2 bolts just above the rear bumper. If I was there already I would help, but I am still tied up for about another week. I sent you an email. |
Post Number: 1606 Registered: 10-2006 Posted From: 76.194.82.182
Rating:  Votes: 2 (Vote!) | Posted on Friday, October 07, 2011 - 6:22 am: | |
"I don't have a manual and the owners don't either plus I don't want to buy one," Not a realistic attitude or productive concept , unless you prefer to re invent the wheel with each and every task. Fine if its your hobby , but a learning experience on someone elses dime is not nice. The difference as explained , yank the cradle , not the parts may save 50 hours , and get a better job in the end. All to not purchase a book? Good luck FF |
Austin Scott Davis (Zimtok)
Post Number: 480 Registered: 9-2006 Posted From: 173.166.209.1
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 9:26 am: | |
Definitely pull the engine and trans on the cradle. It will make this job a whole lot easier. You may want to ask someone if they will let you borrow a manual. Or just scan in the pages you need and send them to you.... . (Message edited by zimtok on October 07, 2011) |
Post Number: 1285 Registered: 8-2006 Posted From: 184.12.182.96
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 9:51 am: | |
I was planning on removing the engine on the cradle as the other engine has the cradle just thought there might be some short cuts,I found a manual but the guy wants 200 bucks for it and the owner won't spring and I really don't need one for one time use,if they are the same as a 4106 shouldn't be a problem ? FWIW FF this deal will not make me a dime the guy is a cancer patient I am just trying to help him I'm not in it for the money never have been anybody that knows me will tell you the same (Message edited by luvrbus on October 07, 2011) (Message edited by luvrbus on October 07, 2011) |
Post Number: 730 Registered: 7-2004 Posted From: 75.91.193.12
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 10:13 am: | |
Clifford, I don't have a 4905 manual but I do have a 4107 manual on pdf. Email me and I'll send you a link to download it. There also some other manuals there that you might use in the future. DF |
Jason Simons (Bigblock01)
Registered Member Username: Bigblock01
Post Number: 48 Registered: 6-2008 Posted From: 75.202.29.72
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 10:18 am: | |
I wish I had a book I would scan and send you the section you need I think it is a great thing you are doing to help him out maybe someone that has what you need will step up and do a good deed. Good luck. |
Bob MacIsaac (Wildbob24)
Post Number: 146 Registered: 5-2007 Posted From: 184.36.50.95
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 3:14 pm: | |
Clifford, I have scanned and emailed you the section in the 4905 manual on engine removal. It's pretty straight forward. The only "trick" I see is to separate the driveshaft at the slip joint, but you already knew that. Hope it helps, Bob |
Post Number: 709 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 07, 2011 - 3:53 pm: | |
I'm sure you've been down this road before but be darn sure the drive shaft U joints are correctly in phase when you slide that slip joint together. I'd mark both halves before sliding them apart. (Words from a guy that just pulled his driveshaft to have it straigntened, balanced and re installed in phase.) Some can only be put together one way, mine could and had been installed wrong before. |
Post Number: 1286 Registered: 8-2006 Posted From: 184.10.185.251
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 09, 2011 - 12:15 pm: | |
Thanks Bob that will help a lots,Dallas I sent you a pm but it bounces good luck (Message edited by luvrbus on October 09, 2011) |
