1 3/8 " fuel transfer hose Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » June 2004 » 1 3/8 " fuel transfer hose « Previous Next »
Bulldogie (69.4.194.41)
Posted on Thursday, June 17, 2004 - 7:04 pm:
HELP, I have looked all over and can't find any 1 3/8" line for my bus, they are 5 1/2" long and there are 6 of them. Tried all the hose shops in the area and also Napa, they can get me a 1 3/8" line but it is only radiator hose which won't work for long with diesel fuel. anybody go any ideas of where to find replacement hose? Thanks for your help folks
bowlingshoegiverouter (65.177.144.237)
Posted on Thursday, June 17, 2004 - 7:09 pm:
yep....go to a place that makes hydrolic lines
Stan (68.150.152.113)
Posted on Thursday, June 17, 2004 - 8:14 pm:
This is a high pressure fuel hose that is a unique size. No hydraulic hose will fit. I found some at a place in Yuma, Az when they invited me in the back to look for myself. Unfortuneately, I don't remember the manufacturer or part number. It might be easier to go to Universal Coach and order by part number.
ralph7 (208.148.72.145)
Posted on Thursday, June 17, 2004 - 9:24 pm:
Last year I purchased as filler hose for my MH and it was $16-$18.00 a ft. at a parts house, not a national high volume store. NAPA was out of stock but cound get it.ralph7 I am in Pa.
Bulldogie (69.4.195.165)
Posted on Friday, June 18, 2004 - 12:08 am:
Stan this is not a high pressure hose, this hose makes the conection between the bottom of the main tank to the bottom of the second tank, the hose is only 5 1/2" long, there are three pipes that span between the tanks and these 6 hoses connect the tank fittings to the pipes inbtween and then to the other tank fitting, that is why it takes 6. Ralph it also is not a filler hose since the filler is a fitted piece that fits right on the face of the main tank and I was told that a filler hose would not hold up to the diesel fuel standing inside it for ever as it transfers the fuel from tank to tank. I STILL NEED HELP FOLKS
Airless in Mississippi (69.92.6.98)
Posted on Friday, June 18, 2004 - 12:48 am:
I would follow the advice for the hose by going to hydraulic they will surprise you on the types of hose they have or carry.
FAST FRED (4.245.230.34)
Posted on Friday, June 18, 2004 - 5:22 am:
Any boatyard of size will have fine USCG aproved diesel fuel hose sitting in rolls.
Post if you want me to ask at my local place about a few feet of hose , but BE SURE you measure the right ID as this stuff neither stretches or crushes much.
bowlingshoegiverouter (63.185.72.205)
Posted on Friday, June 18, 2004 - 7:24 am:
hyd. hose will work,it IS also high pressure,(silly stan)even if you don't need high pressure,first answer was correct,
bowlingshoegiverouter (63.185.64.146)
Posted on Friday, June 18, 2004 - 9:04 am:
look in the phone book,under hydraulic.....also,before stan chimes in again,diesel will not affect it...
Bulldogie (69.4.195.108)
Posted on Friday, June 18, 2004 - 9:34 am:
Hello Fast Fred, you seem to be the only one who realizes that this is a fuel hose (MCI used a non rated hose that swelled up inside which I found was seeping fuel when I started this mess) also there is NO WAY to hook up a hydrolic hose without the connections because you can't squeeze a hydrolic stiff hose with hose clamps (it takes a special press and there is a fitting that goes inside the hose as well as outside) the hose onto the 1 3/8 inch od pipe which makes the ID of the hose to be 1 3/8 inch (that's one and three eighths inch which is very big for a fuel hose). Also unless you happen to find (couldn't find on the www) an ood ball size, most hoses go from 1 1/4 inch to 1 1/2 inch,(one place said they could get it but it only came in 500 ft rolls BUT it wasn't rated for Diesel fuel). Don't think I can afford to buy 500 ft. I have figured out what MCI used though, it was copper refrig fittings and copper pipe because GRANGERS has a stainless steel flex hose(see item # 1A893 at a cost of $26.65 each) for refrig units that will fit perfectly over both ends but you have to braze it on. Since the fittings are longer than the 5 1/2 inche long ones that were holding things together, I will have to cut the pipe shorter and then make a couple of brackets to hang the pipe from the bottom of the bus since MCI also doesn't carry the spacers anymore either. Oh the JOYS of bussing hehehe, so yes Fred if you can find some fuel hose that big I need 3 feet (this gives me space to cut the thing up and still be correct with my length)I would be gratefull since I live in Arkansas and there are not any big boat yards in this area.
BrianMCI96A3 (65.160.215.59)
Posted on Friday, June 18, 2004 - 10:15 am:
Personally, I believe the filler hose would work just fine, if it is rated for diesel, then it is rated for diesel, no matter that the hose does not contact diesel all the time. With that short of a run filler hose should last for years in that application, if not forever.
Brian
Jimmci9 (209.240.205.68)
Posted on Friday, June 18, 2004 - 10:54 am:
cloth-covered-single-wire hose (trade name STRATOFLEX) can be clamped using worm-drive hose clamps....lots of manufacturers use it for suction on hydraulic systems....
bowlingshoegiverouter (65.179.192.170)
Posted on Friday, June 18, 2004 - 11:24 am:
they don't have hose clamps in arkansas,
Posted on Friday, June 18, 2004 - 11:46 am:
Might want to check with Luke at 1-888-coach34. He may have them in stock. If not, he can probably get them or know where to send you. Hope this helps, Jack
PS: We had one of these leaking on our bus when we purchased it in Sept.'99. Repair was part of the purchased agreement and was done by previous owner. It was repaired at Heartland Coach in Arcadia, Florida. Email me if you need more information
FAST FRED (4.245.191.33)
Posted on Friday, June 18, 2004 - 2:21 pm:
Take a caliper or large mike and give me the EXACT inside size of hose you need ,
I'll go see whats on the shelf Sat Am & send it Monday if you wish (and IF they have it).
Bulldogie (69.4.195.153)
Posted on Friday, June 18, 2004 - 4:04 pm:
Talked to Luke and he said that MCI had the hoses but some times the operators make mistakes, so I called again and sure enough they had them so I got 6 and had them ship them at no cost since they said they didn't have them on my last order. Thanks for your help everybody.
