Rick Cribbins (Rc38)
Registered Member Username: Rc38
Post Number: 35 Registered: 4-2004 Posted From: 97.120.190.165
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 4:09 am: | |
Howdy Howdy, I searched the archives, but I'm not having any luck, so I'll ask: Does anyone have the specs on a dipstick for sticking the fuel tank for the main or even the auxillery fuel tank on a 4104? I found it before, but I am unable to locate it now. Currently I use a small piece of bamboo and all though it works well, I thought I'd look for a backup or a better way to check. Thanks! Rick |
Post Number: 1564 Registered: 3-2007 Posted From: 76.4.123.74
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 10:19 am: | |
Rick On my o4 there is a place for a fuel sending unit. It is rather hard to get to it as it is in the rear of the tank. I was able to squeeze in far enough to get it installed and it is a plate that has the screws in it and is located towards the center of the coach . They are nice to have also!! Gomer |
Tom Christman (Tchristman)
Post Number: 343 Registered: 1-2006 Posted From: 66.218.33.156
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 10:46 am: | |
On my transit-I have two 5 bolt round covers on the top of my fuel tank. One I used for a fuel gauge sending unit and the other drilled for my generator fuel pickup and return lines. Always pleasing when you find these kinds of things on the bus! Good Luck, TomC |
Post Number: 716 Registered: 2-2001 Posted From: 68.208.127.66
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 1:49 pm: | |
I measured my tank some years back and found that each inch of fuel is about 5 gallons. I verified this by emptying the tank ( I had removed it for cleaning) and adding 5 gallons at a time. This confirmed the math. (Tank is 120 gallons and is 24" high. Each inch is 5 gallons therefore.) |
Derrick Thomas (Thomasinnv)
Registered Member Username: Thomasinnv
Post Number: 31 Registered: 10-2010 Posted From: 173.87.176.80
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 2:33 pm: | |
. (Message edited by thomasinnv on October 24, 2011) |
Post Number: 758 Registered: 7-2004 Posted From: 98.20.60.176
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 4:26 pm: | |
Rick, to answer your original question... just stuff a piece of wood or romex or plastic or whatever is handy down the fuel fill. When it touches, you are on the bottom. Never go more than 500 miles without fueling, (NOT Gassing up... you don't have a gas engine and you don't have a gas pedal, so you don't have a gas tank). Greyhound and Trailways both didn't spec fuel guages for their buses. Why? |
Post Number: 2133 Registered: 12-2000 Posted From: 174.89.177.190
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 24, 2011 - 9:41 pm: | |
Yup, dipstick cannot be argued with, and will not give a false reading. Old timers said: "Only those with fuel gauges run out of fuel." Have a place in the fuel compartment, if possible, to store the dipstick to contain the wet stink. A piece of tube/hose/pipe to slide it into? happy coaching! buswarrior |
L James Jones Jr (Jamo)
Post Number: 221 Registered: 11-2007 Posted From: 74.67.218.12
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 25, 2011 - 6:55 am: | |
Jim, I thought our 4104's had 140 gallon tanks. I hope I didn't just burst that math bubble you had going. |
Post Number: 1392 Registered: 11-2005 Posted From: 209.240.49.36
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, October 27, 2011 - 4:41 pm: | |
Jamo, They do but I find it impossible to fill because of foaming. just call it 100 gal and plan accordingly, gives a bit of a cushion. |
Post Number: 36 Registered: 4-2004 Posted From: 97.120.190.165
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, October 28, 2011 - 12:57 am: | |
Well the bamboo is working for now, but I know I found a site that had some measurements for a fuel stick. If I find it I'll post it here. I agree, gauges are nice, but I prefer to use the stick. Not as much of a chance of error ;) Thanks for all the great input! Rick |
