Update: Dounan & the 4104 Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » July 2004 » Update: Dounan & the 4104 « Previous Next »
TWO DOGS (63.185.80.233)
Posted on Wednesday, July 07, 2004 - 7:38 pm:
Do just called...he had an injector breake off & it bounced around & took out all four valves in that cyl. they are going back together tomorrow,this time ,with headbolts instead of studs...
John Rigby (24.174.238.253)
Posted on Wednesday, July 07, 2004 - 8:47 pm:
Dounan said the reason he was going back with the bolts was to allow him to put the head back with the water manifold and exuaghst manifolds already bolted to the head. As the bolts will allow extra room, instead of having to lift the head over the studs.
Been there done that.I have studs...
John
Geoff (Geoff) (66.238.120.94)
Posted on Wednesday, July 07, 2004 - 8:57 pm:
Studs are a PIA, but if you use head bolts you need to get a couple of the old studs, cut them so they are only 3-4" tall, and cut slots in them so you can use them as guide studs and still be able to unscrew them and fish them out with a magnet.
RJ Long (67.181.211.253)
Posted on Wednesday, July 07, 2004 - 9:34 pm:
Hey Geoff -
That's the same trick I used to use when bolting a Corvair transaxle to the engine's bellhousing back in the late 60's!!
RJ
PD4106-2784
Fresno CA
TWO DOGS (63.185.72.121)
Posted on Wednesday, July 07, 2004 - 9:47 pm:
I told Do the EXACT same thing...he acted like the old fellow didn't want to do it that way
madbrit (67.136.99.70)
Posted on Wednesday, July 07, 2004 - 10:23 pm:
Not being familiar with the heads on the 4104, but one must take into account that the torque settings for the bolts could well be different than for nuts on studs.
This is because the stud often has a fine thread for the nut whereas the bolt is screwing into the course thread in the block. Also, the twist of the long bolt against the leverage on just the nut can have a strong bearing upon how tight they should be tightened.
Peter.
Posted on Sunday, July 11, 2004 - 11:35 pm:
Geoff.
Great input, I was wondering, how,I would do the line up If I ever changed mine to bolts.
Many Thanks
John
