Households Toilets & Holding Tanks Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » July 2004 » Households Toilets & Holding Tanks « Previous Next »
Nelson Thomas (152.163.252.199)
Posted on Tuesday, July 13, 2004 - 7:38 pm:
I am building with a household toilet 1.6 gal. What size of black waste tank would you recommend? I found a 105 gal waste tank from a vendor on a large online auction site for $199. plus $25 shipping. Also will an RV toilet attach to a household toilet flange for future swap out?
David Anderson (168.215.176.222)
Posted on Tuesday, July 13, 2004 - 7:50 pm:
My Thedford RV toilet fit a standard houshold flange. The bolt pattern was the same.
David
TWO DOGS (65.179.208.85)
Posted on Tuesday, July 13, 2004 - 7:51 pm:
you won't ever want a r.v. toilet..the tank...well,you didn't say how many people & if you plan on being boonedocking..105 gallons is a bunch,I'd say a family of 4 for 4 days...without dumping..
John the newguy (199.232.244.27)
Posted on Tuesday, July 13, 2004 - 9:00 pm:
A good porcelain 'SeaLand" RV type toilet is worth it's weight in
number II. You flush with maybe less than a quart, saving both the
fresh water supply and the amount of dumping you have to do.
And...from what I've heard, their new "VacuFlush" toilets are
even better than their standard version.
Chuck Lott (Chuckmc8) (68.154.4.191)
Posted on Wednesday, July 14, 2004 - 8:40 am:
Nelson, I bought 2 of those tanks that you mention and am using a Sealand toilet- email me if I could be of any help or you'd like a foto-
Chuck
Ed Jewett (Kristinsgrandpa) (4.224.204.142)
Posted on Wednesday, July 14, 2004 - 10:19 am:
Nelson, I haven't bought my waste and water tanks yet but have 3 possible suppliers for them.
RMIF Division of Rotonics
230 Bartow Air Base
Bartow FL. 33830
863 534-1766
110 gal for $120.00 ea.
Tractor Supply Corp
www.mytscstore.com
100 gal for $128.95
Northern Tool and Equipment
www.Northerntool.com
100 gal. 129.95 (in my last sale paper, normally $149.99)
You would have to install fittings yourself but there is an advantage to that, you can put them where you want.
Most people on here talk about having them "spin welded" on, but you can get a plastic welder and do it yourself. Also compression fittings come with gaskets, in various sizes and can be done yourself. Tractor Supply has them in 3/4, 1-1/2, and 2 in.
HTH Ed
David & Lorna Schinske (Davidschinske) (67.216.140.212)
Posted on Wednesday, July 14, 2004 - 10:31 am:
https://www.rvsurplussalvage.com/catalog/display.php?category_id=11
Has holding tanks pretty cheap as well as RV toilets, etc.
David Anderson (168.215.176.226)
Posted on Sunday, July 18, 2004 - 8:11 pm:
Go to Google and search for Ardemco.
They have a big selection.
David
madbrit (67.136.94.210)
Posted on Sunday, July 18, 2004 - 9:18 pm:
And when you have looked up which tank size you want on the Ardemco website, use the same part number and check prices at Ronco, you may find them a bunch cheaper. Using a company to order through, might help too.
Even the 112g tank was UPSed to me.
Peter.
