Merlin P-V (4.242.147.122)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 29, 2004 - 10:39 pm: | |
Am installing new bolt on brake lining 6 bolts per segment 3/8 brass bolts how tight should I torque these bolts ? Thanks in advance Merlin |
think think think (65.121.60.79)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, July 29, 2004 - 11:08 pm: | |
if memory serves, i believe it was 35 lbs final torque, torqued in stages... 15, 25, 35. |
Marc Bourget (209.142.38.81)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 30, 2004 - 10:22 am: | |
Are you sure? These are described as brass bolts. 3/8-16 Steel, grade 5, are spec'd for 36 lbs and I don't think brass matches Grade 5. Onward and Upward Marc Bourget |
Merlin P-V (4.242.147.23)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 30, 2004 - 11:09 am: | |
I am sure they are brass not steel 36 or even 35 lbs seeme tight for the application Merlin |
Luke Bonagura (Lukeatuscoach) (209.247.222.113)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, July 30, 2004 - 11:28 am: | |
Hi Merlin: The 4106 book says 20 to 25 foot pounds. We tighten them up until the lock washer is closed tightly. Caution: over tightening will crack the lining. Also you want to be sure that the surface of the steel shoe is clean and smooth. If not, same problem, lining will crack. I Hope this HELPS!! LUKE at US COACH |
