Michael Lewis (67.160.12.18)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 01, 2004 - 11:14 am: | |
I have removed the door opening lever and arm at the upper hinge, and am left with the stub and the limiter which are held by a large bolt. The nut on the bottom comes off fine, but cannot drive this bolt up or out using a drift. There is an internal spring around this bolt and I'm wondering if it is interfering. Any experience with removing this? Michael |
Jack Conrad (Jackconrad) (207.30.189.75)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 01, 2004 - 4:39 pm: | |
Just a guess. Perhaps the bolt is threaded into the upper or lower part of the door hinge? Have you tried putting a wrench/socket on it? Jack |
TWO DOGS (4.227.118.126)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 01, 2004 - 5:01 pm: | |
or it might be 'pressed' in...just guessing..don't know much about m.c.9.....if it is screwed in ,should have some kind of 'lands' on it,flat spots |
