Buddy Tennison (Buddyten)
Post Number: 101 Registered: 7-2005 Posted From: 24.233.243.30
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, December 11, 2011 - 7:44 am: | |
Gurus: I have an Onan Marquis 7000 Generator. A couple of weeks ago, we used the bus, and it operated fine. Yesterday, took her on another little short trip, and the genny cranks and runs fine, but is not putting out any power. Checked all the breakers, etc, you know the normal stuff you would check. Any suggestions on where to start looking for the problem? |
Post Number: 1429 Registered: 12-2000 Posted From: 71.52.189.221
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, December 11, 2011 - 7:45 am: | |
Loose Connections?? |
Post Number: 1327 Registered: 8-2006 Posted From: 184.10.159.32
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, December 11, 2011 - 10:12 am: | |
Onan's are bad about the reverse current relay going bad or if you lose the shunt field ground it will stop producing power good luck |
Post Number: 725 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 12, 2011 - 9:17 am: | |
Onans will not stay running if they are not making A/C power. They will run until you let go of the start switch. If it continues to run, I would look at a breaker or some issue downstream of the genny. |
Post Number: 1630 Registered: 7-2006 Posted From: 97.225.122.5
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 12, 2011 - 8:16 pm: | |
....AND....Onan breakers may indeed need to be, well,..."replaced"... ...my experience. Don't know why. FWIW RCB |
Derrick Thomas (Thomasinnv)
Registered Member Username: Thomasinnv
Post Number: 38 Registered: 10-2010 Posted From: 72.171.0.149
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, December 12, 2011 - 9:15 pm: | |
Jim Bob that is not true of ALL onans. The older ones do in fact need to see output voltage to keep running, but the newer fully electronic controlled units will run with no output voltage. I have repaired a few that ran but put out no power so I know this to be true from experience. |
Post Number: 727 Registered: 2-2001 Posted From: 184.0.13.120
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 13, 2011 - 10:15 am: | |
Derrick, sorry about that. I obviously over reached my knowledge base. I never get to work on NEW stuff. |
Post Number: 39 Registered: 10-2010 Posted From: 72.171.0.146
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, December 13, 2011 - 6:03 pm: | |
Over reaching my knowledge base is something I am found to be guilty of quite often. LOL. |
