bobm (68.35.160.48)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 08, 2004 - 1:12 pm: | |
I have a 4104 conversion that has always been a little hard to start, but runs fine when started. It also has a very slight battery drain so I have to keep an eye on the levels and charge it frequently. Well, I have been away for eight weeks so I figured I'll have to buy new batteries ,prime the fuel system and use starting fluid to get it started. When I visited my bus the battery voltage was 12.5 and the engine fired on first try. First time thats happened since I have owned this bus. Like some wine old detroits improve with age and inattention |
Robert Wood (Bobwoodsocal) (4.46.108.60)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 08, 2004 - 1:47 pm: | |
Wow, that's cool... go figure! all the best, Bob |
Geoff (Geoff) (66.238.120.86)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 08, 2004 - 1:52 pm: | |
Maybe somebody else has been using it while you were gone... |
John Rigby (24.174.238.253)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, August 08, 2004 - 1:54 pm: | |
Bob. After owning my for 18years 04 I have found out. 1) The battery drains if I leave it connected ( I dont ) because the door switches keep the 12v lights on etc. 2) Mine used to take 20 turns before it would fire, It was always easer to start if I plugged in the block heater. A month ago I changed out all the fuel hose ( the guy who made the lines up was able to reuse most of the fittings to save $ ) NOW IT START ON SECOND TURN, NO BLOCK HEATER. John |
