Regulator Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » August 2004 » Regulator « Previous Next »
AL4106 (149.174.164.23)
Posted on Sunday, August 22, 2004 - 4:18 pm:
Has anybody ever tried to replaced the old 12 volt black box transistorized regulator with an ordinary (heave duty maybe)auto or truck regulator? I don't know why it would not work. Or amI wrong? You know what old age does to the brain.
TWO DOGS (63.156.216.28)
Posted on Sunday, August 22, 2004 - 4:57 pm:
you are wrong...know you don't like to hear that...get the correct part
Posted on Sunday, August 22, 2004 - 4:58 pm:
call LUKE monday...you'll have it in your little hand for the week-end
James Maxwell (Jmaxwell) (66.81.33.3)
Posted on Sunday, August 22, 2004 - 6:23 pm:
AL4106: If price is the problem then u don't even want to hear about the new replacement for the full electronic one used with DDEC II and above. $270, non repairable. U can buy any or all of the components to rebuild your unit from Digi-Key online, or Delco makes complete rebuild kits for them. Two Dogs is correct, u need what u have. My last exposure was abt $75 for a rebuilt exchange.
Chuck Lott (Chuckmc8) (68.215.251.206)
Posted on Sunday, August 22, 2004 - 6:45 pm:
Could he use one of the Xantrex 3 stage regulators?
AL4106 (64.12.116.135)
Posted on Sunday, August 22, 2004 - 7:34 pm:
Unfortunately price and money is always a problem.And fortunately there is a place about 5 miles from me that rebuilds them. This is the second time it's gone out on me. The first time they rebuilded it for me, wasn't to bad. Around
$100. I just thought maybe I could used one from a car or truck. Well from all of you saying the same thing, I think I got the message. Thanks guys I knew I could count on you. AL
Posted on Sunday, August 22, 2004 - 8:26 pm:
don't think I would take it back to that shop,they obviously don't know how to fix it
LHD (216.58.209.69)
Posted on Sunday, August 22, 2004 - 9:27 pm:
Auto regulator works fine Used one 300 amp alt no problem
guy bouchard (161.184.183.10)
Posted on Sunday, August 22, 2004 - 10:11 pm:
with those transistorized regulators, you want to make sure that you never boost start. When using a high output charger you should throw the disconnect switch to off.
(learned the hard way, then read the book)
Guy 4905
Gary Carter (68.25.30.116)
Posted on Monday, August 23, 2004 - 12:37 am:
You can use an after market regulator without problem. However you do need one that can output at least 8 amps to the generator fields.
