john degemis (Degemis)
Post Number: 122 Registered: 3-2008 Posted From: 68.118.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 4:56 pm: | |
My rear air bags empty within a minute of turning off the coach. Front stay up. It sounds like a valve opening. |
Bob Glines (Robertglines1)
Post Number: 68 Registered: 11-2010 Posted From: 75.241.209.149
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 5:15 pm: | |
do you have factory leveling system? Where you level each corner seperate. or just the standard seated coach system with leveling valves. Bob |
Post Number: 69 Registered: 11-2010 Posted From: 75.225.25.92
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 6:42 pm: | |
Also about that year model the tags dumped quickly upon being shut off. Are the drivers dumping also.??? Bob |
Post Number: 123 Registered: 3-2008 Posted From: 68.118.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 7:25 pm: | |
Standard front is one valve and rear corners are seperate. The whole back dumps at once. There are no leeks. It seems like there is a dump valve that is automaticly opening when the coach is turned off. |
Post Number: 70 Registered: 11-2010 Posted From: 75.225.25.92
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 7:38 pm: | |
Your leveling valves in back are fed direct from aux air tank --no valve-- they have no valve between them and the bags. That said if you have level low the air travels from the leveling valves thru norgren valves before going to the air bags.These valves have o rings on them. also are controlled from front by a selonoid. that is the only other way for air to get back by the leveling valves. If you don't have it both leveling valves might be bad. Around that time prevost had problems and had a $1800 fix for it. not necessary. You can do it by re-routeing lines. |
Post Number: 124 Registered: 3-2008 Posted From: 68.118.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 7:49 pm: | |
Thanks Bob |
Post Number: 71 Registered: 11-2010 Posted From: 75.225.25.92
Rating:  Votes: 2 (Vote!) | Posted on Thursday, January 12, 2012 - 7:57 pm: | |
prevostcommunity.com/forum/ new site has at top a article section on how this system functions. I just rebuilt the entire system on my 98 from front to rear.The article is a video with drawings. very well done by owners like you with same problem. Bob |
Post Number: 125 Registered: 3-2008 Posted From: 68.118.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 8:10 pm: | |
opened up my maintenace manual to see where the norgren valves are. Can not find them listed. What elese might they be called? The bus has kneeling and high/low buoy |
Post Number: 72 Registered: 11-2010 Posted From: 75.225.25.92
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 9:01 pm: | |
They will be located outside the rear bay wall in the wheel well compartment. between the leveling valves.. The site I refered you to and the article will show all. Problem probably in front steering compartment control valve body. good luck ck out texas bubbler. Bob |
Post Number: 126 Registered: 3-2008 Posted From: 68.118.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 9:07 pm: | |
Wow that is a great article/video a must see for any Prevost nuts.Thanks again Bob |
Post Number: 73 Registered: 11-2010 Posted From: 75.225.25.92
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, January 12, 2012 - 9:22 pm: | |
Just a bunch with same problem trying to put it in common language. for me dummy language. bob |
Post Number: 127 Registered: 3-2008 Posted From: 68.118.66.52
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, January 13, 2012 - 7:19 pm: | |
Oh well, My coach is setup differant. No 5 valve 2 here 2 there. Called Prevost service that was a waste. Think I will take a break and do something fun. |
