Roadranger Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » October 2004 » Roadranger « Previous Next »
Larry Baird (Airhog) (159.115.178.125)
Posted on Thursday, September 23, 2004 - 5:15 pm:
I am changing out my 871 & 4 speed to a 871T and a 10 speed. I need to locate the shift tower and cables required for the trans. Anyone have any Ideas on how to locate them?
Posted on Thursday, September 23, 2004 - 9:21 pm:
You could try this guy, he seems to have a lot of goodies:
Frank Miller Truck wrecking
15015 northwest mill road
Portland OR 97231
Att: Frank
503-283 1797
Henry R. Bergman, Jr. (Henryofcj) (67.136.241.239)
Posted on Friday, September 24, 2004 - 5:43 pm:
If memory serves, me thinks a lot of the newer type of trucks like some cabovers used a cable shifter system hooked from the cab shifter down and back to the top of the Roadranger.
My Crown uses just the single shift torgue rod all the way back to the RTO-910. It has lots of lube points, which I HAVE NOT gotten to yets. A cable shifter makes lots of sense.
Try the local, heavy truck wrecking yards for a complete cable shifter assembly for a Roadranger, complete with shifter and mount. Then splice or get new longer cables.
TWO DOGS (63.185.65.114)
Posted on Thursday, October 07, 2004 - 11:56 am:
I have a 12 speed "air shift"...if you haven't bought your trans yet...standard "H" patern...4 times .then air shift & go thru again...overdrive .80 to one in top gear
