jjrsmp (69.135.206.67)
Rating: N/A Votes: 0 (Vote!) | Posted on Thursday, September 23, 2004 - 8:11 pm: | |
My Eagle needs a little work in the wheel wells. Rusty around the inner lip to the point I need to reconstruct the sheeting to rivet the lower aluminum siding to. Can anyone offer a few suggestions? Thanks |
TWO DOGS (63.185.72.161)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 24, 2004 - 7:51 am: | |
I'll try.....clean the area real good...take the tire off & look at what was there originally,a sheet metal shop should be able to roll you some stainless ,about 16 ga.since it's a compound curve,you will need to do lots of cutting & turning pieces of metal around to fit,not an easy job,and will take some time....hope that helped some |
Ken (4.152.198.43)
Rating: N/A Votes: 0 (Vote!) | Posted on Friday, September 24, 2004 - 9:55 am: | |
I brought new U profiles from IBP in Fl. You still have some work to make them fit but they look pretty good. Hope this helps. Ken |
