Starting Ether Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2012 » February 2012 » Starting Ether « Previous Next »
Post Number: 1683
Posted From: 70.219.154.44
Posted on Monday, February 13, 2012 - 6:57 pm:
On a trip thru the Mountains this past weekend we ran out of canister Starting Ether. Best source of supply that I am aware of is KBI;decent price, BUT they say UPS wants $25.00 for shipping (Hazmat).:-(
Local facilities here in the third world (Las Cruces) haven't a clue what we are asking for...BUT they have plenty of "spray starting fluid".....NAPA can order, but "doesn't know when it would be here"...(good grief)
Anyone have any ideas on a reasonable supplier?
Thanx
Post Number: 1634
Posted From: 76.4.123.74
Posted on Monday, February 13, 2012 - 7:18 pm:
RC Isn't that the same as the cans here stating spray starting fluid? Hey try a can I believe it is the same tho
Gomer
Username: Luvrbus
Post Number: 1399
Posted From: 184.10.180.173
Posted on Monday, February 13, 2012 - 9:00 pm:
A John Deere dealer will stock it,Gomer the cans I have been around screw into the injection base
good luck
(Message edited by luvrbus on February 13, 2012)
Post Number: 1684
Posted on Monday, February 13, 2012 - 9:51 pm:
Right, LUVR...it is a screw in...like a MAPP Gas Canister...only it screws in upside down in a fixture/tube to the Turbo...:-) :-)
I'll try the local JD, but would guess they "haven't a clue either" (ether):-( :-)
Username: Luvrbus
Post Number: 1400
Posted on Monday, February 13, 2012 - 10:26 pm:
It standard equipment on John Deere diesel tractor the larger one,a truck dealer should have one I've seen those in F/J before
good luck
Username: Jack_fids
Post Number: 1029
Posted From: 72.211.145.15
Posted on Monday, February 13, 2012 - 10:55 pm:
I'll second that...
aside from a minute amount of light oil, "starting Fluid" in a spray can is Either .
The A&P mechanics who cannot afford a 55 gallon drum full, use aerosol cans to clean the stuff they used to dip .
Post Number: 1667
Posted From: 67.238.59.158
Posted on Tuesday, February 14, 2012 - 7:57 am:
Are you starting that often in freezing temps?
FF
Post Number: 1685
Posted From: 97.226.139.140
Posted on Tuesday, February 14, 2012 - 12:03 pm:
Well, not "often", but when I need to start, I need the ether. Only takes a controlled shot or maybe two, depending on how cold it is. Webasto doesn't warm the fuel filter and pump, so unless the ether kicks the system, nothing happens but starter action.
Username: Timb
Post Number: 647
Posted From: 74.251.162.133
Posted on Tuesday, February 14, 2012 - 12:28 pm:
I'm surprised a webasto in the coolant line doesn't do the trick...must be real cold. With my inline coolant heater running it gets the whole block and engine compartment warm and I have started in half a turn down to 17 degrees.
Post Number: 1686
Posted on Tuesday, February 14, 2012 - 2:45 pm:
My "innards" are ALL exposed .....not in a closed in "bay"...engine is mounted amidships, laid on it's side. Cold Wind goes (blows) all around it; fuel lines and tank in the same situation.
FWIW
Post Number: 1687
Posted on Tuesday, February 14, 2012 - 2:53 pm:
Found some in Alamogordo. 33 ounce screw in canister. $53 and some change. NAPA dealer knew exactly what I wanted. Best of all is it is twice the size of my old canister. Had I ordered from KBI, it would have been roughly the same price, including the HAZMAT charge....for half the size!
Nobody within our "metro" (sic) area had the slightest idea what I needed...including Peterbuilt, International, NAPA, CarQuest, and of all places, Tractor and Implement places.
LUVR...that includes local John Deere dealer! They have small cans of spray ether, as do a couple of others. Thanx for the help!!!
Fun Hobby, eh what?:-)
Username: Joemc7ab
Post Number: 621
Posted From: 66.38.159.33
Posted on Tuesday, February 14, 2012 - 3:34 pm:
Chuck
I wonder if your injection pump has seen better days, or the engine compression does not build up high enough, because if the engine is preheated it should not hesitate to start.
Username: Gusc
Post Number: 1459
Posted From: 173.202.22.243
Posted on Tuesday, February 14, 2012 - 5:42 pm:
RC,
It probably would pay to carry a spare spray can just in case this happens to you on the road.
My old 4104 always needs ether in cold weather but it was designed to use it, although not usable from the driver's seat like yours.
Username: Dougthebonifiedbusnut
Post Number: 186
Posted From: 98.216.80.83
Posted on Tuesday, February 14, 2012 - 6:32 pm:
Hey RC, Do you have a compression release on that 220?
Mark Renner (Boomer)
Username: Boomer
Post Number: 258
Posted From: 206.58.200.38
Posted on Tuesday, February 14, 2012 - 10:23 pm:
Need to remote start with the compression release if you are not doing that, but you probably are.
Post Number: 1688
Posted on Tuesday, February 14, 2012 - 10:28 pm:
Joe/Tim...haven't the slightest; albeit this coach has had ether from day one (Flagstaff AZ elevation).
BUT.., I don't understand how the Webasto or any other coolant heater would heat the fuel lines/filter/fuel pump. The engine (and components) is exposed to cold, wind and whatever more than any other vehicle I have seen. For most trucks,buses, etc, there is some bit of heat build up that would take place, I am sure, in the enclosure, even if it is under a hood. This engine is 8 inches off the ground, only a floor above it from front to back (30'+-). The charcoal I used (just a few pieces) burned completely in the 20 minutes or so it took to get the filter and pump "thawed". Lots of breeze, as it were.
From what I understand Diesel fuel congeals somewhat in frigid temps. It seems logical then, the fuel in the line would be less congealed due to thickness of the line (looks like half inch galvanized pipe from front to back). Hence the reason to put the "fire" under the fuel filter (thin metal skin) and downstream from that a few inches, the fuel pump.
Gus...I had, indeed, planned to carry a spare, but at 33 ounces, this is twice the capacity, nearly, of the previous canister, which lasted for a number of years. Meantime, I am fashioning a charcoal container which should do the trick in an emergency...:-)
Doug..... That is new to me...but will look into it. Not sure where to look for that. Any help there would be appreciated. Thanx for the suggestion.
And the beat goes on.....thanx, guys! :-)
Username: Joemc7ab
Post Number: 623
Posted on Wednesday, February 15, 2012 - 1:15 am:
Is your fuel blended differently with the change of season? It certainly is in our neck of the woods.
Post Number: 2272
Posted From: 174.89.176.24
Posted on Wednesday, February 15, 2012 - 2:35 am:
Just how cold are we talking here?
Yes, altitude will have a detrimental effect on getting it started, combined with less cold than at lower elevations.
Something may be wrong here? Wax crystals either form or they don't. Fuel doesn't thicken.
Does your ether system have a thermostat in the wiring?
Post Number: 1691
Posted From: 97.215.116.147
Posted on Wednesday, February 15, 2012 - 4:40 pm:
Joe...good point and I don't have an answer...as you know we are in the southern part of the desert. Any thing is possible in the "third world". :-)
BW....Last weekend was in the teens with wind factor who knows...maybe zero.
I know nothing about wax crystals in diesel, but seems logical to me that the word wax might indicate something other than fluid. Just know that when the fuel is "warm" there is never a problem. Heat of any source usually does the trick....as does ether.
No thermostat that I am aware of. It is a KBI system and have not researched what the makeup of the system. The new canister that I picked up says 200 starts, approximately.
Post Number: 1692
Posted From: 97.226.150.14
Posted on Wednesday, February 15, 2012 - 6:53 pm:
BTW....it might not make a difference.....,but....the Engine is a Cummins 220/Turbo.
Mel La Plante (Mel_4104)
Username: Mel_4104
Post Number: 183
Posted From: 173.180.125.174
RC, why would you use starting fluid or do you have a way to write off the price of an engine rebuild? look at previous post and see the danger that starting fluid does to an engine. do you not have a block heater in it? if not you might find that you can throw that can away and get a lot more lifeout of that engine.
Username: Gusc
Post Number: 1460
Posted From: 173.202.13.166
Posted on Wednesday, February 15, 2012 - 6:57 pm:
Mel,
Your 4104 was designed from day one for ether starting. It even has a little cup on top of the air box for holding ether capsules!!
The capsules are history but I've used spray starting fluid for 75,000 mi with no problems.
Post Number: 1693
Posted From: 97.212.115.118
Posted on Wednesday, February 15, 2012 - 10:47 pm:
Mel....methinks it is the "way" one uses the ether....this coach has over a million miles on it...68-70,000 since an in-frame.
According to the Service Manager at NAU,-the original owner- I have the MSRP- (No. AZ Univ.) when I purchased in 2001, ether had been used since new.
This is a measured shot system that KBI designed. Take a look at their web site...been around quite awhile, I guess. They must have something going for them.
Incidentally, I would use spray too, but no convenient way to shoot it into the system. This has a turbo and it is quite a ways from the air intake to the point of "fire".....might give it a try, though...interesting thought.
Being a pancake installation, the cavity for coolant (normal side of an engine) therefore becomes the "top" and there is a space between the "top" and the coolant....if coolant is not right up to top of cavity (very difficult to accomplish) there is an air space...air space and engine heater do not go well together...BTDT. :-(Cummins acknowledges that.
FWIW, there is quite a bit on the subject in the archives....lots of good information AIR from years past. :-)
Thanx
Post Number: 1669
Posted on Thursday, February 16, 2012 - 8:00 am:
Starting Fluid is FINE , as an alternate fuel for aiding a start at low temperatures.Freezing or so.
The lower the compression , the sooner "low " temp is threshold is passed.
As long as the juice is NEVER used to get a warm engine going (primed),there should be no damage.
A block heater , yes there made to heat the water jacket with propane for the boondockers is always preferred to ether..
FF
Post Number: 2273
Posted From: 174.89.174.10
Posted on Thursday, February 16, 2012 - 11:00 am:
As noted, OVERDOSING is the key to ruining an engine.
The old gel capsules that went in the cup on the intake had a measured dose in them.
The KBI system, and its competitors, introduce a measured dose.
In a proper automatic install, there is usually a grounding thermostat mounted against the engine block by a small bracket. You want to be sure the business end stays against the block, in order to inhibit warm engine injection.
A spray can of starting fluid in the hands of the unwitting or irresponsible... expensive.
Blue flames out the exhaust pipe is definitely NOT your goal.
Best strategy is to spray a sniff of starting fluid directly into the air flow drawn by a cranking engine.
For minimum use, and maximum effect, of a small sniff, introducing it straight into the intake piping is best. Spraying it into the external intake and having to make its way through the air filter promotes using a lot more spray, as the effect is harder to gauge, and some gets hung up in the filter. On coaches equipped with an easily removed air filter, simply pulling out the air filter and spraying into the pipes works well. The ether cup on the horn above the blower is troublesome to reach on some coaches while cranking the engine, due to moving parts. Don't let your clothing get caught up!!!
You will be pleasantly surprised at just how little a sniff it takes, as the temperature in the cylinders most of the time will be almost up to ignition temperature on their own, and needs simply a little nudge to get over the top.
We are after a warming "pop" from the starting fluid fire, so that the cylinder has enough heat in it for the next ignition event on diesel alone.
The damage gets done if the starting fluid is introduced in larger amounts, allowing for a powerful ignition. It is quite likely that ignition of starting fluid can occur earlier during the compression stroke, while the piston is still moving upwards. That's what will bend connecting rods and break piston rings, if the charge of starting fluid is strong enough.
You can imagine how the over reaction towards starting fluid got started by a fleet owner that had an engine failure. In a loud voice of intimidating nature, "If I catch anyone using that devil inspired #$^@#^ in one of my engines again...!!!"
And then the mechanic told a bunch of words to the driver trainer, who didn't really understand, but pretended to, and then he made up a bunch of stuff that sounded good to soften it down for those who arrived afterwards.
And the rest is history?
Rick A. Cone (Uglydog56)
Username: Uglydog56
Post Number: 1
Posted From: 138.163.106.72
Posted on Thursday, February 16, 2012 - 11:35 am:
RC, look at your engine on the left (top) side. On the back of the engine, there should be a lever sticking out. You would use the starting circuit right there, push the lever down, then crank it for a little bit, then throw the lever and she should fire. I will look for a picture of mine and post it.
Larry & Lynne Dixon (Larry_d)
Username: Larry_d
Post Number: 382
Posted From: 50.39.216.227
Posted on Thursday, February 16, 2012 - 11:54 am:
Not the same I know but Dad had a 49 Mack 200 Cummins log truck. Used block heater and a squirt of starting fluid most every winter morning. NE Oregon did get cold back then. Don't remember him replaceing any engines. May be completly different tho. Remember this because it was my job to plug in every nite. Did forget once or twice==Wow.
Larry
Username: Gusc
Post Number: 1461
Posted From: 173.202.0.113
Posted on Thursday, February 16, 2012 - 3:52 pm:
The 4104 Driver's manual called for inserting the capsule, closing the lid which pierced the capsule, and taking a leisurely stroll back to the driver's seat before hitting the starter.
I also used this delay system when using the spray. I tried it once as fast as I could get there but it didn't work as well. The 4104 also has a rear starter switch but using that was too soon also.
I was always very cautious, often not using enough spray and having to do it over. Never failed to start though.
Post Number: 1694
Posted From: 97.32.251.35
Posted on Thursday, February 16, 2012 - 5:51 pm:
Very helpful and informative, folks....thanx much, from everybody!!!
BW, you went the xtra mile! :-)
Rick, looking forward to the pic...
Would be great if Boss Nut could "group" this information with related info in the archives.............
Thanx again everybody!!!
Username: Joemc7ab
Post Number: 628
Posted on Thursday, February 16, 2012 - 7:49 pm:
Chuck
If you are preheating with your webasto, why not look at taking the return line to the weasto and lengthen it and wrap it around your fuelline/filter. Just an idea.
George M. Todd (George_todd)
Username: George_todd
Post Number: 1320
Posted From: 76.94.209.14
Posted on Thursday, February 16, 2012 - 10:53 pm:
Chuck,
BW is right on. The damage done by ether comes from an explosion before top center. A diesel engine will not run on ether alone either. Another cause of ether explosions is engines with glow plugs, mixing those two is asking for a bang.
Now, an explanation on "waxing." Diesel fuel contains paraffin which stays liquefied down to a certain temperature. Below that temperature it solidifies into wax, which obviously won't flow. A diesel INJECTION pump will push wax thru the high pressure lines and injectors, but a DELIVERY pump won't move it at all. So, a waxed fuel system won't run for more than 1 or 2 seconds, period. Heating only the fuel filter won't help, as the line to the tank is solid wax, as well may be the tank.
Diesel fuel is sold in summer and winter blends, the winter blend has a POUR POINT DEPRESSANT in it. In other words, it depresses (lowers) the temperature point at which the fuel will still pour, enough to prevent waxing.
You could get into trouble by filling the tank with summer fuel in July, and not driving the coach until January, when the whole system would be nothing but a block of wax.
Obviously you do not have that problem, as the engine starts and runs with a little ether.
Your problem is that the Webasto is not heating the block enough to make an unassisted start. Turbocharged engines have a lower compression ratio than naturally aspirated engines, to allow for the higher cylinder pressure developed by the pressurized intake air, and don't start as well cold, as a natural engine.
We have emergency generators at most of our medical buildings, and the maintenance company was just talking about an 8V92 for a mountaintop radio station that wouldn't start in the snow, with an electric crankcase heater. After some looking, they figured out that the heater was keeping the crankcase nice and warm, but the heads were stone cold, and under about 20 degrees f, it wouldn't start. Another electric heater in the water loop with a circulating pump cleared up the problem.
G
Post Number: 1695
Posted From: 97.227.244.74
Posted on Friday, February 17, 2012 - 1:50 pm:
Gosh...and it doesn't stop coming!!! what a wonderful medium, Ian...Thanx much for it! :-) :-)
Thanx for a great "possible" suggestion, Joe....
...and George...tell me more about "electric heater in the water loop".. I understand the English, and...I think...the concept....something akin to a radiator line plug in? I have one in our Jeep.
In this last event, last weekend, the Webasto ran all night..to keep the inside of the coach warm... and the starter turned the engine very easily, so I doubt it was a engine "metal warming" issue...could be mistaken, however. AIR, that constant temp is kept in the neighborhood of 100 degrees; something close to that, anyway.
Thanx again, folks!
Username: Chessie4905
Post Number: 2259
Posted From: 71.58.71.157
Posted on Friday, February 17, 2012 - 5:34 pm:
I'm assuming that you don't have electricity for a block heater. Ether works fine for starting, but oil is still cold and stiff and doesn't provide as much lubrication.
Laryn Christley (Barn_owl)
Username: Barn_owl
Post Number: 730
Posted From: 108.4.176.31
Votes: 4 (Vote!)
Posted on Saturday, February 18, 2012 - 11:48 pm:
I always get a kick out of topics that discuss ether. It really brings out the scaredy-cats that spread fear and trembling over its use. Being born on a farm, the first thing required of all infants after they learn to walk, and freeing up their hands, is how to squirt ether into just about anything. I don't see how one could grenade an engine with it unless they intentionally and maliciously tried to do so, and I have witnessed extreme ether abuse. Or is it possibly because where we live here in the mountains it is one of those places where ether works differently than anywhere else, freeing us from the fear of its intended use. Quit wearing out your batteries and starter on those cold days and squirt your bus without guilt. Life is to short to sit around and wait for a block heater to do it's job when you don't have the time.
Username: Luvrbus
Post Number: 1404
Posted From: 24.251.184.12
Posted on Sunday, February 19, 2012 - 8:53 am:
Present day starting fluids are nothing like the ether starting capsules of the past you need to look hard and long to find a spray can that contains 50% ether
Post Number: 2279
Posted From: 76.67.37.56
Posted on Sunday, February 19, 2012 - 1:41 pm:
True Laryn.
The problem is that the abusers of starting fluid may be the source of information for an unwitting busnut, who will regard the advice to empty the can into the intake as gospel.
The guy who got blue flames out the exhaust pipe is going to tell that story to anyone who will listen.
Not nearly as interesting a story to tell or listen to as the proper application of starting fluid.
busnuts, BEWARE THE STORY TELLER, coach maintenance is a boring and tedious pursuit, if it starts sounding exciting, someone's doing something wrong!
Username: Barn_owl
Post Number: 731
Posted on Sunday, February 19, 2012 - 2:12 pm:
I have never started an urban legend before but I will give it my best shot:
The parts manufactures and rebuilders secretly produce and sell ether to naive diesel owners so they will unwittingly trash perfectly good engines. This sinister corporate greed costs these inocent owners thousands of dollars, artificially supporting the parts and repair business and thus keeping the evil shareholders happy and fat in cash.
To counter such wrongs placed upon us I think a few of us should partner together and incorporate an internet starter and battery business. That would show those Wall Streeters a thing or two allowing us all be environmental superstars to henceforth live ether free.
Oh look! I see the Turkey and Deer lining up at my door now to thank me. Looks like I won't go hungry for a while. LOL
Username: Barn_owl
Post Number: 732
Posted on Sunday, February 19, 2012 - 2:24 pm:
On a more serious note, for those who are truly new at this without much experience, Buswarrior's advice should be followed. Ether is a tool to be used like most tools should with some resemblance of sanity. A whole can = to much. A teeny tiny puff = not enough. You would really have to be quite careless and stupid to mess things up with ether. It is not an engine destroying product as some would have you to believe. It is a wonderful starting aid, and back in the old days when it was better, an exciting way to seat a tire.
Post Number: 2268
Posted on Sunday, February 19, 2012 - 5:25 pm:
Seat a tire??? I always used it to REMOVE the tire from the rim.
Username: Barn_owl
Post Number: 734
Posted on Sunday, February 19, 2012 - 6:39 pm:
Few things got more exciting watching a bunch of mountain hillbillies strike a paper match and try to pitch it in a ethered tire. If only we had the video media then like we have today. That would be some side-splitting funny stuff!
Username: Barn_owl
Post Number: 735
Posted on Sunday, February 19, 2012 - 7:05 pm:
Others have done the work for us. Here are just a few:
http://www.youtube.com/watch?v=KI38RZ2f6Ls&
http://www.youtube.com/watch?v=INdTh7dThSA&NR=1&feature=endscreen
http://www.youtube.com/watch?v=5wa1CQ3eZRg&feature=endscreen&NR=1
http://www.youtube.com/watch?v=K-FEkBcepII&feature=related
http://www.youtube.com/watch?v=dJ1k0WuNspk&NR=1&feature=fvwp
http://www.youtube.com/watch?v=E_PlooZL8u0&feature=fvwrel
http://www.youtube.com/watch?v=zi8SMm4SAvU&feature=related
http://www.youtube.com/watch?v=v6RixOkqmSI&feature=related
http://www.youtube.com/watch?v=aEdOWEFALdA&feature=related
http://www.youtube.com/watch?v=aCJGnn0-wD4&feature=related
Post Number: 2282
Posted on Sunday, February 19, 2012 - 8:02 pm:
4th 6th and 10th employ a nice strategy of running a trail of fluid to act as a fuse.
Top marks!
Username: Gusc
Post Number: 1463
Posted From: 173.202.23.235
Posted on Sunday, February 19, 2012 - 8:03 pm:
Laryn,
Your urban legend was started by GM many years ago when they designed ether starting into their systems!!
Username: Barn_owl
Post Number: 736
Posted on Sunday, February 19, 2012 - 9:20 pm:
Gus, then that explains how GM made $7.6 billion in profits last year. Lots of blown up ethered buses in busnut's back yards. Lots of DD parts being sold. LOL
Continuing to some better quality ether/tire vids:
http://www.youtube.com/watch?v=ncWj30tG4gQ&NR=1&feature=fvwp
http://www.youtube.com/watch?v=vdYCsMn4xK8&feature=related
Username: Barn_owl
Post Number: 737
Posted on Sunday, February 19, 2012 - 9:27 pm:
I wonder if the horror stories are from crossover examples of using ether on preheated diesels.
Good example of when not to use ether:
http://www.youtube.com/watch?v=s_LWm4g35Jw
(Message edited by barn owl on February 19, 2012)
Username: Gusc
Post Number: 1464
Posted From: 173.202.1.77
Posted on Monday, February 20, 2012 - 2:55 pm:
I've yet to hear of a DD two stroke being blow up by ether.
Of course nothing is fool-proof when there are so many fools!!
"If a little is good then a lot must be real good!!"
Post Number: 2272
Posted on Monday, February 20, 2012 - 8:07 pm:
since GM hasn't owned Detroit Diesels for some time, they didn't make any of that money on DD parts sales
Username: Mel_4104
Post Number: 185
Posted on Tuesday, February 21, 2012 - 1:09 pm:
LARYN and GUS,thank you for a great day of laughs,there was 7 of us guys sitting around the shop and did you fellows ever get every one laughing and hooting and yelling .we just wondered what part of the hill country you fellows come from.you might ask your self why all the truck man.put a block heater in the engine even for the trucks that run the hillbilly country. if you look at the place where you put a cap of ether in and then close the lid you will notice that the cap. is not under pressure but is indented as it a slight vacuum and when the cap. is punched by the needle , also look at the size of the hole in the needle this is designed to give a regulated amount of ether as it is sucked out of the cap. as the engine turns over during cranking this prevents too much ether entering in to the cyl. and washing off the lube of the cyl walls thus causing damage to the piston rings and cyl. walls. you fellows sure are nice guys as the shop had people laughing all day telling hillbilly jokes, keep them coming guys.
Username: Gusc
Post Number: 1466
Posted From: 173.202.20.86
Posted on Tuesday, February 21, 2012 - 3:29 pm:
Mel,
If anyone used enough ether to wash oil off the cyl walls I wouldn't want to be within a mile of the engine when it cranked!!
Here in the hills of AR we just use a tiny squirt and let it sit a while before cranking. We aren't as brave as you folks up in the frozen north!
We don't use things like fancy block heaters either, we build a fire under the pan till it gets good and hot!!
Username: Mel_4104
Post Number: 186
Posted on Tuesday, February 21, 2012 - 7:27 pm:
Gus,it is sure good to read you fellows post and where you are from, now when any one up here tries starting with starting fluid and someone asks [where in hell did he come from] i can tell them, From AR. thanks
Username: Barn_owl
Post Number: 738
Posted From: 153.2.246.30
Posted on Tuesday, February 21, 2012 - 7:34 pm:
GM had to give the appearance of divesting itself of DD so no one could connect them with such a dastardly plan. They also pay posters on bus boards to post how they sold DD, so we would never suspect them of robbing us like they do when we ether our buses.
For complete disclosure I have a block heater that I do use and am thinking about adding an oil pan heater. I prefer to start a warm engine if I can, but if that is not possible I ether and go.
BTW diesel fuel will also wash your walls on a cold day if it doesn’t light. I don’t put enough starts or miles on my bus to matter and my bus engine was pre-worn out when I got it, so I don’t have the same fear as some do here. I have seen enough crazy things done with ether to know that one can do more than a squirt and run without harm.
I also hope some here can discern between me being facetious and serious. I know it is harder in print than in person. If there are some who are confused, my advice would be to do your homework, and always err on the side of caution.
Username: Barn_owl
Post Number: 739
Posted on Tuesday, February 21, 2012 - 7:39 pm:
The shame is not in using it, but not knowing how to use it………
There are a few states where real men still live without fear. Glad to hear AR is one them!
Post Number: 1702
Posted From: 97.226.28.134
Posted on Tuesday, February 21, 2012 - 10:29 pm:
Username: Uglydog56
Post Number: 2
Posted From: 138.163.106.71
Posted on Wednesday, February 22, 2012 - 4:45 pm:
I forgot to get a fresh pic. Here's one I've already got on photobucket. Look just to the right and down from the williams brake. That is the handle. You pull it down, crank the motor for a bit, and let'er go and she will generally fire.
[IMG]http://i743.photobucket.com/albums/xx74/Uglydog56/crown%20bus%20appraisal%20pics/crownpics 002-1.jpg[/IMG]
Post Number: 1706
Posted From: 97.225.39.178
Posted on Wednesday, February 22, 2012 - 8:45 pm:
Hi, Rick!!!
Reallty appreciate the photo....mine is absolutely not like that,,,,only thing that is even close are the heads...:-) :-)
Is yours a Cummins,a DD,...or?
Many thanx again! Refreshing to see "detail".
Post Number: 1707
Posted on Wednesday, February 22, 2012 - 8:48 pm:
Sorry,,,,,"really" is the word..must be a generational thing :-) :-)
Username: Gusc
Post Number: 1468
Posted From: 173.202.1.240
Posted on Wednesday, February 22, 2012 - 11:15 pm:
I had no idea GM was such a dastardly organization, they sound downright un-American!
I'm going to take them off my Xmas card list!!
Username: Uglydog56
Post Number: 3
Posted From: 24.113.205.45
Posted on Wednesday, February 22, 2012 - 11:59 pm:
For some reason I thought you had a 220hp pancake cummins in a highway crown just like me.
Username: Mel_4104
Post Number: 188
Posted on Thursday, February 23, 2012 - 5:27 pm:
Laryn, you have your statement backwards.the shame is in using it, there is no shame in knowing what damage it can cause an engine. it is sad to see that you think only a few states have men that live without fear,as i have traveled in the US i found the men there as fearless as they are here in CAN. and we do not rate them by their use of a can of starting fluid.
Username: Gusc
Post Number: 1470
Posted From: 173.202.16.145
Posted on Thursday, February 23, 2012 - 9:35 pm:
So, not only is GM dastardly but now I am shamed for using starting ether as GM intended!
This is almost too much to bear!
Post Number: 1711
Posted From: 97.224.46.222
Posted on Thursday, February 23, 2012 - 10:01 pm:
:-) :-) :-) ....and the beat REALLY goes on.
Post Number: 2291
Posted From: 174.91.143.176
Posted on Friday, February 24, 2012 - 2:10 pm:
Well,
newbie busnut reading this in the archives long after this has been rolling...
Do you have any better an idea as to what to do, or not, with starting fluid?
oh well, we be:
Post Number: 1714
Posted From: 70.219.27.27
Posted on Friday, February 24, 2012 - 4:34 pm:
Truly a lot of suggestions/ideas/remarks/concern,etc; albeit, I did buy a new canister of ether and will use it as I "feel the need"....let's see the can says"approximately 200 starts" (18.5 oz).
48 years is a long time, so why change the routine"? (1964 coach)
I'll post when it's empty.:-) :-)
Post Number: 2299
Posted on Sunday, February 26, 2012 - 7:50 pm:
They make an ether injection kit that can be installed to inject into the engine when necessary. You hit a button in drivers area and the inverted can is opened for an instant to allow a little bit into engine. We had one for the Perkins 12kw diesel generator. Worked great when needed. I think the kit is still sold by NAPA
http://www.quickstart-ether.com/
http://www.koldban.com/v/vspfiles/assets/images/documents/131087.pdf
Tom Christman (Tchristman)
Username: Tchristman
Post Number: 358
Posted From: 166.250.65.222
Posted on Monday, February 27, 2012 - 11:34 am:
I don't have a block heater. If I'm in cold weather, the night before I leave I'll put my 500 watt Halogen light under the engine (or any other place you want heated)-it works surprisingly well. You should be able to start that old Cummins in 3 or 4 starting trys.
A 220 with turbo was commonly called a 262hp. I would just simply use the spray can-then you can control the amount and when. Good Luck, TomC
Username: Luvrbus
Post Number: 1413
Posted on Monday, February 27, 2012 - 8:51 pm:
What Gus is saying the old Detroit's had a cup for a measured shot of ether it was a capsule not intended for a spray can and like RCB his is a controlled shot.
FWIW just to show you how long I been around I still have 2 cans full of the Chevron ether capsules for a Detroit lol
Username: Barn_owl
Post Number: 740
Posted From: 153.2.247.30
Votes: 3 (Vote!)
Posted on Monday, February 27, 2012 - 9:14 pm:
Mel,
I don’t see the need to ridicule others who have real world experience with ether. If you have something other than hearsay from around the shop then I would like to hear it. I am always willing to learn new methods and techniques that are better than what I current know. I believe your scoffing is unfounded and you need to post some evidence that ether equals a grenade in the motor. I have offered my life experience with it, and I also work in a UPS mechanic shop where I have access to dozens of fleet mechanics with hundreds of years of combined experience. I am a facility mechanic, not a diesel mechanic myself, but I have turned wrenches all of my life with others who have taught me what I know. And they know how to use ether time and time again without any damage. I also can, and do use ether, without ever a hint of a problem. We are not born with a wrench in our hands; we learn the ins and outs of mechanic work through others and trial and error. We are all ready to learn in detail what you know.
Username: Gusc
Post Number: 1476
Posted From: 173.202.27.11
Posted on Tuesday, February 28, 2012 - 5:02 pm:
Laryn,
Amen to that, it sometimes takes some common sense to do this bus stuff.
There are many many other ways to blow things up other than ether. I use it on gas engines sometimes when all else fails, it just takes a bit of thinking about the proper amount to use.
After 60+ years of being a shade tree mechanic I've yet to have a problem with ether.
No rocket science there, but some people can injure themselves with a bag of marshmallows!!
