grant (65.73.182.168)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 03, 2004 - 4:07 pm: | |
Can anyone explain the major differences between these two transmissions? I have the manual for the VS2-8 and yet the VH-9 appears to be the transmission installed in my bus. Thanks |
jimmci9 (209.240.205.61)
Rating: N/A Votes: 0 (Vote!) | Posted on Sunday, October 03, 2004 - 10:30 pm: | |
1 of the major differnces is the shifting between the torque convertor range and direct range... the vh uses an external air shift... the vs2-8 uses an internal oil-pressure type clutch...ive got a vh in an old 5105 gm... |
Phil Dumpster (24.17.4.245)
Rating: N/A Votes: 0 (Vote!) | Posted on Monday, October 04, 2004 - 5:50 am: | |
The VH9 is a bit different from the VH in your 5105. The VH9 dates from 1968 or so through the introduction of the V730. |
steve souza (Stevebnut) (24.60.226.230)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, October 05, 2004 - 7:29 am: | |
the vh9 is a single speed trany with hydraulic acting as first then torque converter lock acting as second. The vs2-8 is the same with the exception of a splitter on the input shaft of the trans which gives a third range of overdrive. Steve |
