Draining Fuel Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » November 2004 » Draining Fuel « Previous Next »
Matt
Posted on Saturday, November 13, 2004 - 5:09 am:
I would like to drain the fuel tank on my mc8, can anyone tell me how much of a job this will be, is there a plug on the bottom of the tank and can you easly get to it.
David Winters (Hilltop)
Posted on Saturday, November 13, 2004 - 7:29 am:
There is on my 5a. Panel in front of tank has 4 screws in it.
Chuck Lott (Chuckmc8)
Posted on Saturday, November 13, 2004 - 10:19 am:
OK Matt, here's the deal- Flip open your fuel door access (Panel), like when you are fueling. Reach up thru there and theres a 3/8" nut in each corner (9/16 wrench). Easy to get to . Remove those nuts and the whole fuel door lifts up and out. Theres a plug on the front of the tank at the bottom for draining the fuel.
If you have 5 gals if fuel in the tank- No Prob. If theres a lot of fuel in the tank......Better find some clean plastic 55 gal drums!
If you need to take out the tank, check the archives here for info on that's done, or you can email me. Hope this helps
