Eagle Tag Axle Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » December 2004 » Eagle Tag Axle « Previous Next »
jjrsmp12
Posted on Tuesday, November 30, 2004 - 1:36 pm:
1980 Eagle Model 10. Where do you position the jack to jack up the tag axle? Also, is this a true tag axle? It doesn't look like the axle extends from wheel to wheel. Thanks
J.C. Barnett (Eagle)
Posted on Tuesday, November 30, 2004 - 2:48 pm:
It is not a tag axle it is a bogie axle. It is located in front of the drive axle.
jjrsmp12
Posted on Tuesday, November 30, 2004 - 3:07 pm:
After reading through some posts, I now understand that. Where do you jack it up? Mine shows a small portion of axle extending from the wheel, then it stops.
Posted on Tuesday, November 30, 2004 - 8:27 pm:
I just use a 20 ton bottle jack placed directly under the axle spindel. I guess I'm calling it correctly. You have to crawl behind the tire to place the jack at that position.
David
jjrsmp12
Posted on Thursday, December 02, 2004 - 8:01 am:
I assume that is the correct place to jack? It looks like a 1 foot piece of axle and then stops. Correct?
