Double clutching Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2004 » December 2004 » Double clutching « Previous Next »
Lin
Posted on Friday, December 31, 2004 - 2:41 pm:
My Superior has a 5 speed manual transmission. I do not know what brand. I have never double clutched when shifting since it has synchromesh and shifts fine normally. Someone recently told me that I should be double clutching anyway. Is there any sense to that? If so, why?
TWO DOGS
Posted on Friday, December 31, 2004 - 3:33 pm:
depends on how often you want to replace trans.& clutch...
Posted on Friday, December 31, 2004 - 5:55 pm:
If you are not grinding gears while shifting then you do not need to double clutch. The synchros are doing that for you. This is assuming that you are using the clutch normally for shifting.
Richard
Gary McFarland (Gearheadgary)
Posted on Friday, December 31, 2004 - 6:46 pm:
He's referring o another thread where they are talking about crashboxes.
Matching RPMs while downshifting is not a bad idea even in a full sync box.
Gary
