Bay Door Locks Log Out | Topics | Search
BNO BBS - BNO's Bulletin Board System » THE ARCHIVES » Year 2005 » January 2005 » Bay Door Locks « Previous Next »
t gojenola
Posted on Tuesday, January 11, 2005 - 1:52 am:
Many moons ago somebody (I believe it was Steve Fessenden) posted that he had bought some electric door lock actuaters and was going to install them to lock his bay doors. I'm now considering the same thing on my 4106.
So, have you, Steve, or anyone else actually done this, and tell me about the results if you did.
tia
tg
Posted on Tuesday, January 11, 2005 - 5:24 am:
I simply lifted up the closing handles and cut a slot in them.
An eye bolt installed beneath in the door pokes thru the slot enough so a set of Master keyed alike locks can be used.
"Locks ONLY keep out an honest man" so a 3/8 eyebolt is enough to discourage most amateurs , and not too much damage will need repairing should a THIEF wish to look into a usually completly empty bay.
Works for me,
Stephen Fessenden (Sffess)
Posted on Tuesday, January 11, 2005 - 4:27 pm:
I never did it. I still have the locks. My current bus has key locks on all doors and that is enough.
jimmci9 #2
Posted on Wednesday, January 12, 2005 - 7:42 am:
saw a rally neat set-up on david anderson's eagle... maybe he'll chime in....
John that newguy
Posted on Wednesday, January 12, 2005 - 5:28 pm:
I just found out that all MCI keys fit all other MCI locks!
Luke Bonagura (Lukeatuscoach)
Posted on Wednesday, January 12, 2005 - 7:54 pm:
Hi John:
I know that someone has given you some bad info!!!
The fact of the matter is that if anyone buys a NEW, MCI with entrance and baggage door locks, they have their own company key code!!!!
We store over 100 MCI's on our lot for numerous companies and have keys for many of them, and I can tell you for a fact, that if one is missing a key, we can go through all of the key boxes we have (segregated by bus model), and will not find a key to start it!!!
I hopes this puts this rumor to rest???
We have a lock supplier, with our own codes, for any locks we supply to customers, or install on their buses in our shop.
I hope this HELPS!!!
Happy & SAFE Bussin" to ALL!!!
LUKE at US COACH
Merlin Moon (Mrmerlin)
Posted on Wednesday, January 12, 2005 - 11:06 pm:
I keep confusing my lawn tractor key with the Prevost ignition key ... really !!! They look very similar. You'd think at least a big bus ignition key would be a tad more impressive. Then Prevost uses Ford keys for the bay locks. Go figure !!!
Posted on Thursday, January 13, 2005 - 1:53 am:
My 81 MCI-9 uses Ford key/tumbler combination for the bay doors, entry and under the driver access.
Neat system uses a 1/4" square stock to lock the handle. It's professionally done. I'm not sure that International Bus Parts would offer this setup.
Onward and Upward
John that newguy
Posted on Thursday, January 13, 2005 - 11:57 pm:
Well Luke...
I have a 1979 MC9. The ignition key is also the door bolt key.
I've had two different MCI owners take a peek at my MC9
while I was away. Both gained access using their own keys
in my door.
But thank you for the enlightenment regarding the newer coaches.
Posted on Friday, January 14, 2005 - 1:47 am:
John -
Why not pull the lock cylinders out and have a locksmith rekey them for you. Fairly simple procedure, and not that expensive if you just bring in the cylinder assemblies.
FWIW,
John that newguy
Posted on Friday, January 14, 2005 - 7:43 am:
Yessir! I plan to do that. I was trying to decide between changing
out the entire lock (going to a RV type door latch system as well
described on this board), or simply changing the tumbler/key. After
the second "intrusion", I'll have to do what's fastest... the tumbler.
Most all of the small RV bay lock keys will open things like the gas
station pump doors and compartments, other RV compartments,
and assorted other nifty types of compartments. It should be
understood, that those "other keys" will open the RV compartments
as well.
H3 (Ace)
Posted on Friday, January 14, 2005 - 11:20 am:
Our 92 H3 has TWO keys.... one for the ignition ONLY and ONE for all other doors being entrance and bay doors!
Both are different in looks and design and niether of them will work on my friends H3 nor will his work on mine!
Ace
John that newguy
Posted on Friday, January 14, 2005 - 12:54 pm:
A lot of the commercial bus lines like to keep things simple.
Making one key fit all buses' ignitions and doors, simplifies
the changing of drivers at the various stops and garages.
The buses I drove way back when (sound of random harp strings)
didn't have keys at all, to start the bus.
