captain ron (Captain_ron)
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 11:08 pm: | |
I have 4 headlights on my bus but only the 2 outer ones work. I do have high and low beams in them but visability is poor. What are the 2 inner lights for? and should they work off the same switch? I just discovered they don't work this evening so I haven't checked bulbs, also neither of the 2 left front signals work the one on the side or the one on the very front. again it was too dark and cold to check bulbs. just trying to get her safe and road worthy. |
Rating: N/A Votes: 0 (Vote!) | Posted on Tuesday, February 22, 2005 - 11:36 pm: | |
wouldn't it be strange...if you were heading south....& ...the Rians were heading north...................................................... |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 12:10 am: | |
Your a sick man  |
Stan
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 8:18 am: | |
The inner lights are high beam only. When on high beam, all four lights should be on. Inner and outer lamps have a different number |
BrianMCI
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 8:29 am: | |
Just as Stan says... Brian |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 11:38 am: | |
ok either they're not hooked up or both are burned out. |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 1:50 pm: | |
..... or your HB switch is burnt out ..... |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 2:08 pm: | |
more likely a loose connection...lets see ...no lights...no horn....no turn signals...no alt..no trans. hey does ANYTHING work...if a cop stops you...sing him that song.............  |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 4:18 pm: | |
I've got a different song for the cops. My brights work on the outside pair. I can go from high to low beam. so I probably both burned out or disconected. Just think 2Dogs I almost bought an airplane once |
Brian Brown (Fishbowlbrian)
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 5:31 pm: | |
CR, you sound like my kinda guy. So, forget swampland in FLA. I've got a slightly-used, slightly-converted Fishbowl I could horse-trade with 'ya! All in the soothing shades of gold and ochre and brown. She's a creampuff!
BB |
Rating: N/A Votes: 0 (Vote!) | Posted on Wednesday, February 23, 2005 - 5:44 pm: | |
Well the real reason I bought this particular bus is because I'm realy into James Bond. and the sales guy convinced me it was in a James Bond movie. After I bought it I figured out why. Every time I take off it leaves a smoke screne and an oil slick  |
