Closed: New threads not accepted on this page |
Thread |
Last Poster |
Posts |
Pages |
Last Post |
  | Crown HIGHWAY Coaches | R.C.Bishop | 7 | 1 | 8-31-01 10:38 am |
  | Cummins Pancake Engine | FAST FRED | 5 | 1 | 8-20-01 5:46 am |
  | Dinette | Stan | 1 | 1 | 8-07-01 2:18 pm |
  | Different types of foam insulation | Jim Stacy | 3 | 1 | 8-31-01 9:40 pm |
  | Eagle 01 front cap?? | Gene Lewis | 2 | 1 | 8-30-01 11:37 pm |
  | Eagle 20 Caps. | Luke Bonagura | 3 | 1 | 8-30-01 9:01 pm |
  | 4104 shifting problem | Bob M | 3 | 1 | 8-30-01 10:54 pm |
  | New bus pictures | max muston | 11 | 1 | 8-30-01 10:02 pm |
  | Window Covering | Manfred Boden | 1 | 1 | 8-28-01 8:46 pm |
  | Inverter wiring--THANKS | Steve Fessenden | 4 | 1 | 8-29-01 8:21 am |
  | Basement Heat Pump | max muston | 5 | 1 | 8-29-01 3:49 pm |
  | Inverter wiring | Steve Fessenden | 5 | 1 | 8-28-01 9:55 am |
  | Eagle 20 Inspection | mark murray | 3 | 1 | 8-27-01 12:06 pm |
  | Got A Bus....HELP! | David & Lorna Schins | 6 | 1 | 8-27-01 8:19 pm |
  | Eagle Voltage Gauge Problems | tfones | 2 | 1 | 8-26-01 8:13 pm |
  | Air levelling sytems | Jim Stacy | 21 | 1 | 8-31-01 9:56 pm |
  | Air filter dp | max muston | 5 | 1 | 8-26-01 9:17 pm |
  | Window removal and installation for GM 4106? | Gary Carter | 2 | 1 | 8-25-01 5:49 pm |
  | Tach Wire ? | Phil Smith | 5 | 1 | 8-25-01 1:43 am |
  | Scoop results | Steve | 6 | 1 | 8-27-01 9:08 am |
  | Bad fuel? | dougthebonifiedbusnu | 3 | 1 | 8-22-01 9:51 pm |
  | 8V71 Oil Pressure | Phil Smith | 4 | 1 | 8-22-01 3:48 pm |
  | Eagle conversion to Series 60 | Ol Jim, hisself | 2 | 1 | 8-22-01 10:01 am |
  | 318 Detroit Diesel Engine...Educate me!! | Phil Smith | 3 | 1 | 8-21-01 11:27 am |
  | Access panels?? | CoryDaneRTSII | 3 | 1 | 8-21-01 6:33 am |
  | Rear view camera | JayJay | 4 | 1 | 8-28-01 1:19 am |
  | Fuel and storage | FAST FRED | 7 | 1 | 8-28-01 5:33 am |
  | 6V92 DDEC engine torque | RJ Long | 2 | 1 | 8-18-01 1:43 am |
  | Mci9 retartder | Luke Bonagura | 4 | 1 | 8-18-01 9:54 am |
  | Need Ideas for a roof hatch | Ted Calvert | 6 | 1 | 8-19-01 10:20 am |
  | CUMMINS HOT ROD | FAST FRED | 1 | 1 | 8-15-01 8:00 am |
  | Eagle I.D.plate location??? | Alan Baker | 3 | 1 | 8-16-01 9:34 am |
  | Diode for oil cooled alternator | Greg Roberts | 2 | 1 | 8-14-01 9:10 pm |
  | RTSII tough vinyl floor covering | Toolman | 5 | 1 | 8-14-01 10:27 pm |
  | What I did for my Summer Vacation | Jim Wilke | 7 | 1 | 8-15-01 7:37 pm |
  | 8V71 Running Temp | Chuck Harris PD4104 | 5 | 1 | 8-11-01 8:10 pm |
  | I need advise ,should I buy this bus? | ShawnRay | 1 | 1 | 8-09-01 3:51 pm |
  | Skinning a buffalo | Scott Whitney | 4 | 1 | 8-30-01 2:30 am |
  | New Home No Start | Frank Allen | 4 | 1 | 8-09-01 4:36 am |
  | Brake problems | dougthebonifiedbusnu | 2 | 1 | 8-07-01 9:05 pm |
  | 4905 to 4106 Steering | RJ Long | 8 | 1 | 8-06-01 9:51 pm |
  | Keyless entry and security system | Clarke Echols | 4 | 1 | 8-05-01 4:25 pm |
  | Frame Coatings | CoryDaneRTS | 3 | 1 | 8-03-01 6:10 pm |
  | Floor slide | Scott Whitney | 15 | 1 | 8-06-01 3:17 pm |
  | Stop!!!!!!! | Mark Radius | 6 | 1 | 8-01-01 9:56 pm |
  | Problems building air pressure | Mark Radius | 11 | 1 | 8-10-01 4:42 pm |
  | Why Shoulder Harnesses? | Clarke | 11 | 1 | 8-05-01 4:42 pm |
  | Entertainment Center | Scott Whitney | 6 | 1 | 8-08-01 2:11 am |
  | SpeedO Diagram | Al B | 4 | 1 | 8-03-01 8:52 pm |
  | Camping in TN | davidschinske | 2 | 1 | 8-15-01 3:09 pm |
  | Hey FAST FRED -- MCI 9's available in New Jersey? | FAST FRED | 3 | 1 | 8-29-01 5:23 am |
  | Looking for R L | Ian Giffin | 2 | 1 | 8-21-01 8:22 pm |
  | (was "Bus in Yard") Local laws re: parking | john | 3 | 1 | 8-21-01 5:57 pm |
  | Bus in yard, part 2 | Henry, eh | 13 | 1 | 8-25-01 8:54 pm |
  | Bus in yard - logistics challenge | john | 4 | 1 | 8-17-01 11:52 am |
  | Pre-trip Checks | FAST FRED | 6 | 1 | 8-22-01 5:34 am |
  | Some tough questions (that are preserving my sanity...) | Steve Fessenden | 8 | 1 | 8-17-01 6:36 pm |
  | Blue Bird Busers | mike_c | 1 | 1 | 8-15-01 3:49 pm |
  | Kneeling front????????/ | stan | 2 | 1 | 8-16-01 1:28 pm |
  | Do some campgrounds deny access to conversions? | FAST FRED | 7 | 1 | 8-29-01 5:28 am |
  | Weight and Balance Issues in Bus Conversions? | FAST FRED | 10 | 1 | 8-19-01 5:53 am |
  | License Requirements for Conversions. | Geoff | 10 | 1 | 8-18-01 9:44 am |
  | GOT THE BUG I CAN'T GET THAT EAGLE BUS OUT OF MY MIND | RAY PRATT | 4 | 1 | 7-30-01 10:15 pm |
  | YOUR Cooling System MAINT BASICS | s cole | 4 | 1 | 8-18-01 4:11 pm |
  | TRANSMISSION PROBLEM | don | 7 | 1 | 8-27-01 9:02 pm |
  | 4104 Air Leaks | phil shannon | 3 | 1 | 8-24-01 9:35 am |
  | Steering Wheel | Rodney Cook | 3 | 1 | 8-24-01 5:25 pm |
  | 4106 GVWR | Jim Stacy | 4 | 1 | 8-15-01 11:00 pm |
  | Rear Axle Lube | Frank Allen | 3 | 1 | 8-13-01 9:29 pm |
  | Window seals and screens | Jerry Nanson | 1 | 1 | 8-10-01 8:16 pm |
  | Parts hunt part 3 | Pete Hyser | 3 | 1 | 8-13-01 7:38 am |
  | Skins | Jerry Nanson | 5 | 1 | 8-02-01 4:23 pm |
  | Looking for GMC repower guys | Jim Stacy | 5 | 1 | 8-12-01 10:41 pm |
  | 06 fan drive | AL MORENO | 2 | 1 | 8-11-01 9:39 am |
  | 1973 MCI 7 Play in Steering | Lee Dove | 3 | 1 | 8-22-01 10:09 pm |
  | MC 7 Serial Number | Glenn | 1 | 1 | 8-22-01 6:28 am |
  | Trim Moulding | Jim Ashworth | 2 | 1 | 8-14-01 7:06 pm |
  | Eagle Front & Back Emblems? | Eric Brown | 2 | 1 | 8-31-01 7:48 am |
  | Eagle Int. Rally-Oct 2001 | David & Lorna Schins | 3 | 1 | 8-21-01 2:43 pm |
  | Recorded history of Eagles ?? | Gene Lewis | 1 | 1 | 8-19-01 1:17 pm |
  | Queen bed and water tank location | madbrit | 3 | 1 | 8-19-01 2:29 pm |
  | Eagle VIN plate found!! | doug woodin | 1 | 1 | 8-19-01 12:55 pm |
  | Eagle VIN plate location??? | Loydd Fones | 2 | 1 | 8-21-01 11:59 pm |
  | Eagle 05 heater core | Loydd Fones | 2 | 1 | 8-22-01 12:13 am |
  | ABC's NJ Eagle Model 20 | D.T. | 12 | 1 | 8-24-01 9:00 pm |
  | Going to start on Eagle this year. | Mcroy Gardner | 8 | 1 | 6-21-01 2:39 pm |
